Sponsored by:
Sponsored by: DashLynx
2005 GT Conv
Old 08-31-2015, 07:40 AM
Cin K
Cin K's Avatar
Default 2005 GT Conv
I had a oil/fuel filter/tune up change a month ago. Since then my fuel has dropped to 10 mpg! I used to get 18-20. Have had it back to the shop 3 times and was told each time that they could find no leaks, etc. The mechanic, who works at an Ethonol Free station, insists its the fuel and I should use his only. I have never used anything other than Shell regular, and never had problems until the oil change/tune up. Any ideas??
Cin K is offline
Old 08-31-2015, 08:39 AM
88 orangepeel notch
88 orangepeel notch's Avatar
The moderators will probably leave this thread open and delete your other one as this is a better location for it.
Just out of curiosity, do you smell gas at all outside the car ? Any small puddles or drips evident ?
88 orangepeel notch is offline
Old 08-31-2015, 08:51 AM
Cin K
Cin K's Avatar
No gas smells. But have noticed a small puddle near the drivers rear of car. It doesn't smell of gas tho?? Isn't that where the filter is? Fuel neck filler problem perhaps? I'm at a loss.
Cin K is offline
Old 09-01-2015, 06:34 AM
88 orangepeel notch
Yeah, I'd investigate that leak. Might not smell like real gas if your running ethanol blend by you.
Old 09-01-2015, 07:29 AM
Cin K
Cin K's Avatar
Yea, I have not been using the Ethonol Free. Just regular Shell. I was wondering if he didn't really change fuel filter or if the one he did install is bad. I was thinking of changing it myself and see if that makes a difference.
Cin K is offline
Old 09-02-2015, 07:02 AM
88 orangepeel notch
I actually just replaced my fuel filter a couple months ago, and the new filter had a pin hole leak in one of the welds. Good luck
Old 09-02-2015, 07:50 AM
Cin K
Cin K's Avatar
That just reassures me that it may be that is what is the problem is. I'll lyk how it works out. TY for your help 😊
Cin K is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
mdj89
10-26-2015 11:53 AM
mdj89
10-08-2015 09:16 PM
69Volunteer
09-30-2015 10:39 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: 2005 GT Conv
