Sponsored by:
Sponsored by: DashLynx
cam for 351w
Old 10-26-2015, 05:37 PM
tmc351w
tmc351w's Avatar
Default cam for 351w
Hi All,
Iam building a 1992 351w with stock 1973 351w dooe heads with 1.84"x1.54" valves with 60.4 cc chamber. Stock heads CFM rated at 181 cfm @ .500. I need 260 hp @ 4400 rpm with great low end and mid range torque at 3500 rpm to pull a heavy load like a big RV. Using a edlebrock performer intake with a 4160 holley 4bbl. compression 9:1 with flat top pistons
I have a cam picked out with duration @ .050 of 210 intake/214 exhaust with valve lift of intake .477 / exhaust .485 with lsa of 114 degrees for good idle. Do I have too much valve lift for the stock dooe heads @ 181 cfm @ .500?
Thanks
tmc351w is offline
Old 10-27-2015, 07:32 AM
88 orangepeel notch
88 orangepeel notch's Avatar
What does the cam manufacturer say. I'm no cam guru, but they'll know.
Sounds like it'll be fine, but always check PTV clearance.
88 orangepeel notch is offline
