Procharged 4.0
Old 11-06-2015, 01:17 AM
jlopez07
jlopez07's Avatar
Default Procharged 4.0
Hey all,
a guy on facebook is selling his procharger P1SC head unit. Says it originally came on a 07 v6 kit. Has roughly 5k miles on it. Looks like its just the head unit itself. Im very interested in purchasing it since hes selling it for $1000. What all do I need to make it work on my 4.0? My main concerns is that Ill be adding my longtubes here shortly after getting my inspection done and I am not sure it this will work with them or not. Any advice is greatly appreciated. Just looking to get a little more fun out of my dd till I decide on which V8 I want to get.
jlopez07 is offline
Old 11-06-2015, 08:59 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Sorry I can't help, but if you don't get a answer here, try the Tech Section for your '07, or the Pipes,Boost and Juice. Good luck
Or there's contacting the manufacturer directly, since it sounds like you'll be shopping there soon anyway.
88 orangepeel notch is offline
Old 11-06-2015, 11:36 AM
Moderator
JimC's Avatar
If all you are getting is the head unit, you will need a lot more.
Plate to mount it to the engine
Maybe new pullies (can't recall if the pullies are swapped )
Correct size injectors
Correct size belt
Intake and connectors
Air filter
Tuner and tunes
Heat exchanger for inter-cooling
It will probably cost more to piece it together than a complete new kit
JimC is offline
Old 11-07-2015, 12:06 AM
jlopez07
jlopez07's Avatar
thanks for advice! He ended up selling it.
jlopez07 is offline
