clutch time
clutch time
Ok it is clutch time on my 2012 v6 ,6 speed and could use some advise from those who may have already done the job,
before I stick this old lame back under the car and pull the trans, i'm looking at kits to use.
on the list is the ram hdx with a ram fly wheel or one of the others. I see AM no longer sells the kit other do, a gt uses a 1 1/8th by 26 spline the v6 uses a 1 x 23 so a gt clutch won't work
what I want is a 100% street able set up. nothing like the center force I have in my blown 07, more like the stock unit but with out the vibrating dual mass flywheel .
any one done a swap with good street results? which kit did you use
