Sponsored by:
Sponsored by: DashLynx
84 5.0 Stalling at running Temp
Old 06-16-2016, 01:10 PM
Quicklike84fox
Quicklike84fox's Avatar
Default 84 5.0 Stalling at running Temp
Hey guys, New to the forum! Recently picked up my second Fox body. 84 convertible 5.0 5 speed car. It has a rebuilt 302 out of an 86 f150 in it. It is Carb car. Previous owner put full exhaust set up on car, king cobra clutch and high flow oil pump. I got it for a little cheaper then usual because the car when it reaches running temp stalls out and won't fire and run again until it has cooled down. Also I noticed if I start it and try to hit the gas to hard it stalls or sputters. Any ideas? I have a few, just curious before I start digging into it!
Quicklike84fox is offline
Old 06-16-2016, 03:32 PM
jdthedj10
jdthedj10's Avatar
Just a hunch but, try to ice the ecu and see if it helps. I had that to happen back in the day and placed a bag of ice on the ecu to get home.
jdthedj10 is offline
Old 06-17-2016, 09:21 AM
Quicklike84fox
I had a mechanic friend of my tell me its the ignition module that ford had alot of problems with them during those early 80s years. I think I'm going to swap that out and see what happens! then maybe ill move onto the ECU! Thanks!
Old 06-20-2016, 02:52 AM
Mr. D
Mr. D's Avatar
Does it shut off like turning the key, or start to run rough & then quit? If it shuts off like turning the key I'd look at ignition, but if it runs rough & then stalls, my guess would be carburetor. Does it run fairly clean at wide open throttle? If so, it may be running too rich at idle when it warms up. Automatic choke adjustment or functioning, or jetting is too rich. If people have messed with the carburetor I'd start there. It sounds like a carburetor problem to me. Check into that before you start spending money on guesses. Just because a carb is rebuilt doesn't mean it's right! It can be clean, rebuilt, yet all messed up! Can you get a another stock carb. for a 302 to try on it?
Mr. D is offline
Old 06-20-2016, 06:54 AM
Quicklike84fox
Thanks man! The carb isnt rebuilt but that does make a little more sense...He had someone tune it down to get it through inspection a couple of years ago. It runs good both wide open an idling initially. It literally craps out when it gets up to temp. It can be running full speed or sitting still once it gets up to temp it'll just sputter and die.
Old 06-20-2016, 07:18 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum.
Like Mr.D says, you'll have to determine what your car is missing when the troubles start, fuel or spark. Next time it acts up, check for spark first, then fuel by looking down the carb while working the throttle. We'll need to know which one of those 2 your missing before we can give accurate info.
Good luck
88 orangepeel notch is offline
Old 06-26-2016, 02:08 AM
Mr. D
Mr. D's Avatar
When an engine is cold it needs & can use a much richer fuel air mix. When it warms up the same overly rich mixture can cause stalling & missing! I bet that if you get a good carburetor rebuild it will solve your problem. If you can race the engine & it runs smoothly, but stumbles & dies when you let it slow down... it sounds like you need a good rebuilt or new carburetor. If an engine will race to a high rpm cleanly it eliminates everything but the idle circuits in the carb. IF you are going to keep the car permanently a new carburetor might be an idea! Like everything the actual castings do wear out & rebuilding may not make an old, "monkeyed with" carb. work perfectly! It's not easy to get a "GOOD" rebuilt carb for old cars. If you do get a rebuilt carb try to get a recommendation for a good rebuilder. Many places that rebuild parts do a lousy, cheap job! As the guys into Mustang restoration where to get a good rebuilt carb. I'd go new myself... if the carb is the problem. Good luck!
Mr. D is offline
Old 07-03-2016, 11:14 PM
5.0 bird
5.0 bird's Avatar
Sounds like your ignition module on the distributor is bad. You can take it off and have it checked at a parts store.
5.0 bird is offline
mirrormask
05-12-2016 01:09 PM
tkfozli
03-03-2016 03:51 PM
Rory Fraser
02-20-2016 10:32 PM
Ayeecole
02-10-2016 02:50 PM
StangBoy86
04-14-2003 12:29 AM
Quick Reply: 84 5.0 Stalling at running Temp
