getting most out of 1994 500 gt
Not getting good mileage. generally getting between 11.5 and 13.5 mpg. Please advise on different things to do to improve mileage. I am not a car mechanic. Copier/printer tech. Your help is appreciated. Frank
Spend more time on the highway, and less time in lower gears.
If that doesn't help, it might be a problem with the car. How many miles are on it, and what does the service history look like? It might be time for a tune-up...
are you using the OEM air filter? see if you can open the air box, its pretty easy (you can google it) and if it has an aftermarket or third party air filter, put a motorcraft air filter in - pretty cheap to get and can be had at your local oreilley's - also try to keep a lighter foot on the gas pedal
otherwise basic maintenance, oil change every 3k miles with a bottle of chevron with techron in the gas tank, engine air filter change every 30k miles (always use the motorcraft one), fuel filter change every 30k miles (not sure if the 94 has a fuel filter?), tranny fluid change every 50k miles (if its an auto), cabin filter whenever it smells (not sure if the 94 has a cabin filter?) - and your car should run forever like new
btw thats pretty cool, a 94 with only 58k miles O.o do those have a place in the odometer for hundred thousand miles? or do they just rollover to 0 after 99,999 miles?
