Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-09-2004, 06:17 AM   #31
Muffstain76
Default RE: GEARS
here's a question for everyone,..I acquired a 91GT Aod and noticed the rear was/hadbeen changed. It has discs but still it is a four lug rear, 3.55 ratio.
I really didn't think that stangs came with discs until 94 which they also upgraded to 5-lug. My friends think this is a 93 Cobra rear end. Does anyone know whether or not rear disc brakes were available with 4-lug 93 or older set up?
__________________
There's always someone faster,...ME
Muffstain76 is offline   Reply With Quote
Old 04-04-2004, 01:58 AM   #32
dghost22
Default RE: GEARS
If I am not mistaken all of the v-8 stang from 86 on had 8.8 rears... Please correct me if I am wrong.
__________________
86 Mustang GT, 4.10 gears, Tremec 3350 close ratio, stage 2 ported edelbrock upper and lower intake, 70mm throttle body and EGR, full exhaust.....etc.......
dghost22 is offline   Reply With Quote
Old 04-12-2004, 06:02 PM   #33
89ImportEater5.0
Default RE: GEARS
there are 2 ways, there is an ID tag on every rear. that might be hard to read so hear is what i recomend to do,you need 2 people jack the back of your car up. put it in nutral with the e-brake off, block the one tire so that when you spin it they both spin in the same direction, get one of you buddies to craw underneath and watch the drive shaft, market in on the driveshaft and the rear with white out or something, then spin the tire one full rotation and count how many times the drive shaft turns. it won't be exact but it will be close this should give you some idea of ur gears. if you don't know what the ratio's mean like a 3.55 it means the drive shaft turns 3.55 revulutions for every one turn of the tire.
89ImportEater5.0 is offline   Reply With Quote
Old 07-19-2004, 04:33 AM   #34
98cobrasvt
Default RE: GEARS
4:10s all the way!!! Have fun...
__________________
All them curves, and me with no brakes....
I'm a yellow fellow!
98cobrasvt is offline   Reply With Quote
Old 07-27-2004, 06:04 PM   #35
Jeffs_GTstang
Default RE: GEARS
is this a job better left to the professionals?
__________________
White '96 Mustang GT Convertible
Hurst Billet/Plus shifter
Magnaflow Magnapack cat-back
More to come...
Jeffs_GTstang is offline   Reply With Quote
Old 09-13-2004, 03:47 AM   #36
tyybo
Default RE: GEARS
so is it usually about 150 or so then to get them put in?
__________________
"For all single women, its either get carpletunnel or find a man....or both"
---------------------High Low ---
Tonight Jan 13 Clear N/A -26° ..We have no high temp
90 F150
95 mustang GT (R.I.P)
94 mustang GT (on the way)
66 stang
tyybo is offline   Reply With Quote
Old 11-09-2004, 12:25 PM   #37
WorldMustang
Default RE: GEARS
I believe the 7.5 rearend was replaced in 87 with a 8" in all fox body mustang
[IMG]local://upfiles/10267/CF00C2A7C49248E1858CA1CC1C424A76.jpg[/IMG]
__________________
Gary Moore
World Mustang Assoc
WorldMustang is offline   Reply With Quote
Old 11-20-2004, 12:51 AM   #38
import slayer
Send a message via AIM to import slayer
Default RE: GEARS
why not just look at the ID tag on the driver's door. What letter is there?
I forget the codes offhand but I can find out if you tell me what the code is.
__________________
1982 GT 351w(.060),10.7:1 flat top pistons, ported & polished heads, 1.94/1.60 valves,stealth intake, 750 holley dp, Comp 274XE cam, C-4 tranny with 3700 stall converter, 8.8 rear, 4:10's, subframes,electric fan.
Tons of mods that are too much to list
import slayer is offline   Reply With Quote
Old 01-12-2005, 10:39 PM   #39
Ontherocks98
Default RE: GEARS
i hate to sound like a complete noob, but can someone clear up the whole "low end" and "top end" performance..i think i have a pretty good idea about what it means..but im better off hearin it from guys who actually know what they're talkin about
thanks
__________________
2002 V6
Magnaflow dual exhaust
cold Air intake
soon to come:
u.d pulley?
Ontherocks98 is offline   Reply With Quote
Old 01-13-2005, 01:12 AM   #40
fordguy17
Default RE: GEARS
top end means you will have more power and torques in the upper rpm range and you will have more top end if you ever get the chance to top out your car. (unlikely) low end means you will have more grunt off the line.
__________________
8.804 @79.49 Stock motor aod car.
Totalled 2/8/08. RIP.
[img][/img]
fordguy17 is offline   Reply With Quote
14, 200509, 247, 28spline, 355, 373, 75, 88, affect, axle, ford, gear, gears, mile, mustang, rear, times
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
