Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-25-2005, 10:27 AM   #51
04GTPony
Send a message via Yahoo to 04GTPony
Default RE: GEARS
yeah i know what you mean about the 85mass and the 75tb...i havent had it dyno tuned yet because im waiting for my stage 2 cam to come in and now that im getting the 410s im going to wait a little longer and i think and hope thats a good combo. thanks for the info.
__________________
Mac 85mm massair, ceramic longtubes, plenum, 75mm throttlebody, catted H-pipe, 2chamber flowmasters, stage 2 cams, 410's, high energy mounts, chiped, minor supsension work, micky's.
04GTPony is offline   Reply With Quote
Old 03-11-2005, 10:15 PM   #52
speedracer2627
Default RE: GEARS
OK, I have a 99 Salen Cobra that I want to take to shows "in and out of state" and put a few ricers in their place around town but I am not 100% sure about 4:10s from all the opinions. The thing that would solidify it for me is what would the tach be at when you are doing 80mph in fifth gear?......right now it at 2200 "boring".....I don't need to save THAT MUCH gas. Anybody have any stats?
speedracer2627 is offline   Reply With Quote
Old 03-20-2005, 12:57 PM   #53
Lizardking
Default RE: GEARS
3.55s are an all around great gear for most people. 3.73s or 4.10s are great if ypu go to the track or if you dont use your Stang as a daily driver. Remember lower gears will result in higher engine rpm and there will be alot more cabin noise.
I put 3.73s in my 88GT with a Flowmaster exhaust. At the time I was driving 70 miles one way to work, I drove the GT once or twice a week and my Ranger the other days. After the change I couldnt hardly stand to take the GT out on the highway. I loved it in town, but long highway trips were out.
Another option if you have an auto is to chip it and reprogram the shift points, that helps alot.
My 88GT had 3.27s from the factory. If you have a 7.5 and want to upgrade to the 8.8, you may be able to j-yard shop and get the 8.8 and better gears for less than the cost of just new gears.
If you already have the 8.8, you may be able to j-yard shop and get better gears, then sell your 8.8, and get better gears for nearly no cost.
__________________
2005 Red fire Deluxe, Charcoal interior, AT the only option.
- Dealer installed Brushed aluminum dash kit
- 50% Tint
- GT Premium rims/tires
- GT Mufflers
- IUP shifter
Lizardking is offline   Reply With Quote
Old 03-26-2005, 08:14 PM   #54
SpecterGT260
Default RE: GEARS
Ok, I'm drivin a 2000 GT. It's manual so ive been lookin at 3.73's. I've been hearin talk about bad highway mileage with that kind of ratio, and that sucks. This is my only option for a vehicle (not that i would want to drive something else) so should i start thinking about something alittle more tame? it would be awesome if someone running 3.73's had calculated their mpg and could let me (and some others im sure) know the actual figues
[IMG]local://upfiles/14327/F5F19F46C91D45EAAA30D9EE5796E5CA.jpg[/IMG]
__________________
RIP http://www.mustangforums.com/m_2239114/tm.htm
"slow" and "stock"
FQuick
SpecterGT260 is offline   Reply With Quote
Old 03-26-2005, 08:21 PM   #55
SpecterGT260
Default RE: GEARS
AAAAHHHHHH! I forgot to add, i was also lookin at a tuner. apparently (correct me if im wrong) they reprogram the ECU, and you can get it to run on less gas. Would this be a bad idea (like damaging the motor) if i were to take long trips, or would the only side effect be less power while im runnin it like that? Otherwise this seems like a good solution to the fuel economy situation.
[IMG]local://upfiles/14327/2F4B6D5B4B3D4CF1AE97CD52404E1550.jpg[/IMG]
__________________
"slow" and "stock"
FQuick
Old 03-27-2005, 12:53 PM   #56
clutchsix
Default RE: GEARS
ive been looking at 8.8 rearends for my V6. I came upon an 8.8 Traction-Lok Posi off of a Crown Victoria. I was wondering would it fit on my Mustang. the rearend is 28 spline. Someone told me the Crown Victoria has different mounting points than a Mustang?
__________________
2004 Volvo S60 R
2002 Mustang GT, Vortech S/C - Sold and missed the most...
1994 Mustang Cobra - Blew engine
2001 Mustang - Sold
clutchsix is offline   Reply With Quote
Old 04-14-2005, 10:10 PM   #57
5.0 Balla
Default RE: GEARS
What would be a better gear for an automatic 5.0, with a built motor and going to be supercharged soon?
5.0 Balla is offline   Reply With Quote
Old 04-28-2005, 03:04 PM   #58
usernamesarelame
Default RE: GEARS
I am fairly sure i have 4.10s in my car. simply due to the high RPM at highway speed. close to 3k at 70 mph or so.
mileage is bad, but i can't imagine THAT much worse than stock. i get approx. 16 mpg give or take, in a combination of around town and highway driving. i spend probably 75% of the time going around town and the other 25% of the time doing 55+ on the highway. what do you guys get with stock gears, for mileage?
-kevin
__________________
usernamesarelame is offline   Reply With Quote
Old 05-13-2005, 05:37 PM   #59
clewis1082
Default RE: GEARS
I did a lot of work to a '66 that I used to have but I've never worked on any of the late model mustangs at all. Is it going to be much different between a late model and an '05 for changing out the gears or is it basically going to be the same?
clewis1082 is offline   Reply With Quote
Old 05-17-2005, 02:32 AM   #60
01GTType
Send a message via AIM to 01GTType
Default RE: GEARS
Ummm, how come no one has said anything about 4.30's thats what I'm putting im my Stang. They are on there way here as I type..
__________________
01GTType is offline   Reply With Quote
14, 200509, 247, 28spline, 355, 373, 75, 88, affect, axle, ford, gear, gears, mile, mustang, rear, times
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
