Sponsored by:
Sponsored by: DashLynx
computer chips
Old 02-12-2004, 12:32 AM
GTRedfire03
GTRedfire03's Avatar
Default computer chips
I got a question I hear that adding a computer chip will hurt the engine b/c the chip makes it run a max performance all the time. Is this true? and also any one you guys recommend one chip being better than another? thanks</P>
</P>
GTRedfire03 is offline
Old 02-12-2004, 03:39 AM
ricekiller2003
ricekiller2003's Avatar
My friend has what's called a "Superchip Microtuner". It plugs under your dash computer port (under the plastic dash and to the right). </P>
All you do is turn the car off, plug it in....then it asks you questions like</P>
Do you want to use the economy 89 octane or performance 93 settings.</P>
Run fan at 160,180,200 degrees</P>
Change top speed</P>
Change rev limiter</P>
Gear setting 2.73, 3.27, 3.73, 4.10...etc.</P>
It's pretty good for a couple of things. I'm getting one as soon as I save up $300. But it works by changing the fuel/air ratios and the timing. It's not a seat off your pants feel, but none of the chips are. The great thing is that it stores your factory settings on the unit (but doesn't allow other cars to use it), so when u want the performance settings off, you plug it in again and answer the questions..........whew!</P>
ricekiller2003 is offline
Old 02-12-2004, 11:11 AM
03trubluestang
03trubluestang's Avatar
GTRed: It'll void your warrenty..if u care
03trubluestang is offline
Old 02-12-2004, 02:04 PM
vfast
I ♥ Acer
vfast's Avatar
none of the off the shelve chips run at max. only way you will get that is go to a tuner and run it on a dyno..why waste you $$$ on one of those..this is why pms,tweecer,f.a.s.t. or become the norm for computer
vfast is offline
Old 02-14-2004, 06:46 AM
NeoTokyo
NeoTokyo's Avatar
Mod chips hurt your car because they arent made specificly for your car, you might have modded your car and it wont know that, its just trying to change set calibrations in your car. They really arent worth the money. As my late X-Fiance's mother use to say "They aint worth the powder to blow em to hell"</P>
Your best bet is to go to a shop, have it dyno'ed and tuned. Thats your best bet and it will absolutly NOT hurt your car. And btw, just because it asks you what diff setting you would like to run at, doesnt make your stock 2.73's run like 4.10's <IMG src=smileys/smiley2.gif border="0"></P>
NeoTokyo is offline
Old 02-14-2004, 03:01 PM
99 cobra
99 cobra's Avatar
Sup,</P>
And where do you get this "Superchip microtuner" For some reason i am not believing the makes stock gears work like a 4.10. How could that be possible with actually having the 4.10 gear?</P>
</P>
</P>
99 cobra</P>
99 cobra is offline
Old 02-14-2004, 05:43 PM
NeoTokyo
NeoTokyo's Avatar
Exactly Cobra, thats what i argued abouve.
NeoTokyo is offline
Old 02-15-2004, 09:09 PM
99 cobra
99 cobra's Avatar
hey man,</P>
i just wrote it again to make sure he sees it.</P>
</P>
99 cobra</P>
99 cobra is offline
Old 02-15-2004, 09:17 PM
mkspeed26
mkspeed26's Avatar
put the money towards something better
mkspeed26 is offline
Old 02-16-2004, 02:18 AM
Birdieman4
Birdieman4's Avatar
I swear by the use of a MAF tuner instead of a chip...
02 Saleen S281E
Birdieman4 is offline
Quick Reply: computer chips
