p2195
Old 05-05-2006, 02:41 PM
*bmxking*
*bmxking*'s Avatar
Default p2195
so i just had some header and cai put in my car and i ahd it programmed (sct2).. and about a week ago i had my check engine light come on. p2195. i cleared the code and it came back.. so i looked it up and found out that it said it was the right side o2 sensor is stuck lean.. so i check for exhaust leaks and found one in the header so i tighten it hoping to fix the prolbem and it came back again[:@].. so i was jsut woundering if any of u have had the same problem or could give me some tips to fix it...
*bmxking* is offline
Old 05-05-2006, 04:53 PM
sowaxeman
Retired Moderator
sowaxeman's Avatar
Default RE: p2195
What CAI did you get, and what tune did you use - just the canned SCT, or a specific tune for the actual CAI you bought? Could be a bad tune - you might need a more specific tune for your CAI.
I flashed my car with the canned diablo tune with the Steeda CAI and I got a lean CEL. Got the correct Steeda tune, and that corrected the problem.
sowaxeman is offline
Old 05-05-2006, 05:50 PM
*bmxking*
*bmxking*'s Avatar
Default RE: p2195
i have a mmr cai and i used the 89 canned tune.. i called the guys from steen racing were i bought it from and i going to go get it dyno tuned on tuesday so hopefully that will take care of the problem.. thanks for ur input
seatommyboy
05-02-2014 12:30 PM
mdg
10-01-2013 02:42 PM
06MUSTANGGT24V
09-27-2010 07:10 PM
Alec
09-02-2010 10:54 AM
Mustang7599
11-25-2009 09:12 PM
Quick Reply: p2195
