Rattle noise from car when going over bumps.
Old 06-22-2006, 12:24 PM
EJMStang06
EJMStang06's Avatar
Default Rattle noise from car when going over bumps.
I have about 1000 miles on my gt now and when I am driving over bumps which are not that big I hear some type or rattle noise from the car. I tried to move around the jack and the wheel in the trunk, and that did not change much. It sounds like it is coming from the suspension or wheels or something. Does anyone have that problem or should I take it in?
Thanks a lot
EJMStang06 is offline
Old 06-22-2006, 01:20 PM
06GT4RAD
06GT4RAD's Avatar
Default RE: Rattle noise from car when going over bumps.
It is probabaly the exhaust mid pipe hitting the upper panahrd support. Take it in and see what they do.
Richard
06GT4RAD is offline
Old 06-22-2006, 11:30 PM
Rypper1
Rypper1's Avatar
I took mine in for the same thing. Sounds like mine is coming from the front end and sounds like a loose tie rod. Dealer couldn't find anything wrong, naturally. I have noticed that it is much less apparent if I soften up the tires a little. Dropped the pressure down to about 30 psi and it barely makes a noise. Pumped it up to 36 and it makes all kinds of noise.
Randy
Rypper1 is offline
Old 06-23-2006, 02:23 AM
HypromanGT
HypromanGT's Avatar
Have them look to tighten the vertical sway bar link on the right side (front). I have what I think is the same problem you are describing, but haven't taken it in yet.
I got this information from this thread
If you look far enough down the thread, there's a nice diagram of the theorized problem.
HypromanGT is offline
Old 06-23-2006, 11:09 AM
EJMStang06
EJMStang06's Avatar
I actually found out the problem. It is my exhaust. I just installed axleback flowmasters on my car. It is something that is making a rattle sound on the passenger side. I was under there briefly yesterday to see if anything is loose. I am going to tighten it up today after work. Is there any suggestions of what to do. It seems that it is either the bracket, the clamp or the downpipe. What is a good method of getting the passenger side to stop?
Thanks
gagemcc
08-17-2015 10:30 AM
BCATL79
3.7L V6 Technical Discussions
08-13-2015 07:41 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Itstbrown
08-09-2015 03:49 AM
Quick Reply: Rattle noise from car when going over bumps.
