XCAL CODE P0113
RE: XCAL CODE P0113
http://www.obd-codes.com/trouble_codes/index.php
"intake temp too high"
MAF sensor harness loose?
Overheating?
Little guy under your hood with a torch on your intake?
Overheating?
RE: XCAL CODE P0113
Yikes:
P0018 - Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A
Description: The powertrain control module (PCM) monitors the variable camshaft timing (VCT) position for a misalignment between the camshaft and crankshaft. The test fails when the misalignment is greater than 1 tooth.
Possible Causes: Worn timing chain tensioner
Worn timing chain tensioner arm
Loose timing chain
Ok, is this the "turbo" car? Or are there other mods?
Sounds to me like either:
a. something is off in your wiring (short/open/intermittent connection - bad PCM?)
b. something is off in your motor...
So, I would pull the negative terminal on your battery to reset things if you haven't, but if that doesn't clear it up - I am out of ideas...
Loose timing chain
RE: XCAL CODE P0113
One more idea...
While you are out there tugging on wires...
Check the VCT sensor/control harness... It sticks up from the front of the valve covers...
I guess I could imagine if one of those came lose it could do something like that...
Good luck...
Good luck...
lincolnshibuya
12-08-2015 04:37 PM
