Rear creaking noise - 2007 GT Conv
Old 12-20-2006, 04:50 PM
flguy
flguy's Avatar
Default Rear creaking noise - 2007 GT Conv
I have been trying to solve a mysterious creaking noise coming from the rear driver's side of my 07 GT Conv. Doesn't matter whether the top is up or down.
I've had it to the dealer 3 times, and each time they say it's fixed, the noise comes back after a short while. There was even a Ford field rep out looking at it, and they replaced the "LT RR Lower Control Arm". All was fine for about 40 miles (over the course of 5 days...I don't drive much), then the creaking came back.
Another weird thing about it is that the noise goes away after getting the car washed. Then it comes back 30 mins later, like the water created some kind of lubrication which then dried out.
UPDATE: I decided to spray silicone lube on the bolts inside the body panel in the little side pocket area where the top folds down. I also sprayed all the suspension bushings/joints I could see on the left side. The noise went away. I don't know if it was the suspension or those body panel bolts (why there are bolts instead of welds I have no idea). So my advice to anyone with creaking problem is the spray everything with silicone. Silicone may dry out over time and the noise may come back, but at least you can pinpoint the offending part more easily this way.
flguy is offline
Old 12-20-2006, 05:49 PM
TPony
TPony's Avatar
Default RE: Rear creaking noise - 2007 GT Conv
Partner, recommend you re-post in the Vert Tech Sub-forums...under the General Tech Forums. Bet our folks there will shed some info...we are trying to get the sub-forums going and we'll appreciate all vert questions be addressed over there....thanks my friend.
TPony is offline
bjdutch2005
03-24-2017 03:38 AM
robjh22
Suspension
09-08-2015 12:47 PM
Webster454
09-07-2015 04:59 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Rear creaking noise - 2007 GT Conv
