first race in my stang, now windows wont roll up
RE: first race in my stang, now windows wont roll up
http://www.2005stang.com/viewtopic.php?t=1087
Fuse box Fuse box - description of fuses
Hey,
Its fuse number six (i think) in that kicker panel. Its a 5A fuse and in the manual it's listed as Accessory Delay Feed. Change it and it will start working again. I'm thinking you probed wrong. Your windows should not work, and your radio should be dead. However, if you take a wire and run it from the positive terminal on your amp to the REM terminal (make sure its a 5A fused wire), the amp and radio will turn on.
I can tell you exactly what happened. You grounded the REM wire going back from your radio to your Amp. Check your ground going to your amp and I bet you will see that its touching or touched the REM wire coming back from your radio.
Let me know...
~Fred
Note: If you take it to the dealer, tell them what I said here or else its going to take them a couple hours to figure it out. Mine said it would take a couple days, so I took it to my house and figured it out myself in 20 minutes (i just probed everything).
Note 2: Do yourself a favor and don't put the fuse box cover back on.
Let me know...
~Fred
replaced that fuse, still nothing... then noticed i replaced it with the same fuse. everything works now. thanks a million
The guy had long tube headers, 4:10's, sct tuner, pulleys, exhaust work, throttle body. thats all i can remember right now. im meeting up with him again on sat, to go to the track aslong as weather permits
ORIGINAL: 01SilverGT
Hopefully you get the problem fixed. And what mods did the guys 04 GT have to hang with your car for that long?
ORIGINAL: s197
~Fred
ORIGINAL: Chef
hey fred tt you work for nasa or what? anyhow thanks for helping this brother out. i like expertise.
Haha, I think I've blown that fuse for the same reason about 10 times. I'm drawing alot of power from it (because I'm to lazy to rewire stuff). Drawing REM for the headunit, and two amps and its also powering my concealed radar. Next time it blows I'm putting in a 7.5A.
~Fred
