Whats the biggest engine?
Old 06-06-2007, 04:18 PM
Stkjock
Retired Mod
Stkjock's Avatar
Default RE: Whats the biggest engine?
you could shoehord that V12 in if you remove the passenger cabin and drive from the trunk!
Stkjock is offline
Old 06-06-2007, 04:32 PM
p51mstg
p51mstg's Avatar
ORIGINAL: acascianelli
Lycoming XR-7755
127 Liters
36 cylinder radial
5000hp @ 2600rpm
http://www.pilotfriend.com/aero_engines/aero_xr7755.htm
Now, THAT'S Rock and Roll!!!!! [sm=icon_rock.gif]
p51mstg is offline
Old 06-06-2007, 04:57 PM
A_J
A_J's Avatar
There was an article in the most recent issue of 5.0, I recall, ofa guy that did the 427, and apparently it didn't require much, if any, relocation of things in the engine bay. If I had to go big-block, I'd go that route, and who knows, maybe by the time you'd want to do it someone may have a kit.
A_J is offline
Old 06-06-2007, 07:51 PM
explict
explict's Avatar
ORIGINAL: jrm1900
V12, 22 Liters, 1550HP @ 2300rpm [8D]
4600 lbs haha 3 lbs/hp
explict is offline
Old 06-06-2007, 08:23 PM
kthulhu
kthulhu's Avatar
Bah... all you underachievers.
Here's what I'm swapping into my GT. I'm sure it'll fit fine as long as I don't have a strut bar.
Seriously though, check this thing out: 108,920 Hp and 5,608,312 ft/lbs at 102 RPM
http://people.bath.ac.uk/ccsshb/12cyl/
[IMG]local://upfiles/57675/30AB1498A3B540CAB63FCAC31408E048.jpg[/IMG]
[IMG]local://upfiles/57675/08D9567ACF0941CDBD2EF5CA372C24A5.jpg[/IMG]
[IMG]local://upfiles/57675/5B278BB10B8848BEAD997DB718C2DF67.jpg[/IMG]
kthulhu is offline
Old 06-06-2007, 08:52 PM
jrm1900
jrm1900's Avatar
ROFL!!!!! That's what I am talking about [8D]
jrm1900 is offline
Old 06-06-2007, 09:00 PM
SpecterGT260
SpecterGT260's Avatar
http://videos.streetfire.net/search/...43e1d136a9.htm
SpecterGT260 is offline
Old 06-06-2007, 09:18 PM
MexGT
MexGT's Avatar
ORIGINAL: kthulhu
Are those comp cams?
MexGT is offline
Old 06-06-2007, 09:52 PM
jrm1900
jrm1900's Avatar
Bahh that is nothing check this out lol:
http://www.conleyprecision.com/movie.mpg
[IMG]local://upfiles/60520/F3A9FF532DB747AB9117D264DFE29545.jpg[/IMG]
jrm1900 is offline
Old 06-07-2007, 09:45 AM
baha
baha's Avatar
Why not put a $7000 514ci 600hp Ford Racing engine in? it equates to about 8.4 liters!! it has a compression ratio of 9.8:1 so it runs on pump gas, add 150 shots and be done!
You're gonna need a C6 transmission to handle that power.
Check out this link also:
www.mustangengines.com
And BTW...there are stroker kits for the Ford 460 not only to 514ci but to 557ci!!! 9 liters!!
baha is offline
Quick Reply: Whats the biggest engine?
