Cooling System Upgrade
Old 08-27-2007, 07:53 AM
sactown
sactown's Avatar
Default Cooling System Upgrade
Has anyone upgraded their cooling system?? With the SC now installed I am a little worried about the heat here is Sac.
sactown is offline
Old 08-27-2007, 10:25 AM
hammeron
hammeron's Avatar
Default RE: Cooling System Upgrade
are you thinking of the s/c intercooling system,
or the engine's cooling system
hammeron is offline
Old 08-27-2007, 11:46 AM
shooter23
shooter23's Avatar
If you dont have an intercooler, i'd start with that...but seeming as you have the Saleen 475 system, im sure you already have it.
Other than that, you can change the rad out for a lightweight aluminum one, but the difference wont be that beneficial. I'd recommend the electric water pump, it'll keep the engine cycling coolant at every speed...
Other than that, im all out of ideas...the cooling system is strong, just keep on top of your flushes...dont want the PH level to change...
shooter23 is offline
Old 08-27-2007, 02:23 PM
A_J
A_J's Avatar
If we're talking about radiators and not intercoolers, look up Fluidyne, they make aluminum race radiators and I recall they recently released one for the S197. I had a Fluidyne in my 328 to upgrade the lousy plastic radiator in that car and was quite pleased with it.
A_J is offline
Old 08-27-2007, 02:29 PM
sactown
sactown's Avatar
engine cooling alread got the intercooler.
sactown is offline
Old 08-27-2007, 02:31 PM
sactown
sactown's Avatar
still using the stock water pump? I was looking at the fluid dyne last night, pretty nice. What about larger or more agressive fan?
sactown is offline
Old 08-27-2007, 02:54 PM
blackhorse05
I ♥ Acer
blackhorse05's Avatar
like i said in my pm. its reaaly not needed at this point. yea a alum rad would be nice. they sayyoull loose weight. but its a bigger rad so more fliud. a wate pump is available. but i would not recomend that unless you are only going to make this a track car. im sure some people run them but if it dies. so does your motor. as for heat, i would say just get a biiger resevoir for the s/c i/c and a little bit for the motor. keep them at the proper levels and ou should be good.
as for the radiator. if you were to get functional hood, then a rad would be awesome, but your stock would still be sufficient. if you look at the gt500. you notice how the vents are at the front of the car. well at high speeds those vents are taking hot air out while pulling air through the rad, thats why thier at the front. is kind of streamlined if you think about it. that is a fuctional set up, and thats why i want a hood with vents in the front.
blackhorse05 is offline
Old 08-27-2007, 02:58 PM
sactown
sactown's Avatar
I have been checking out the ram air hoods just have not found one I really really like.
sactown is offline
Old 08-27-2007, 03:00 PM
blackhorse05
I ♥ Acer
the Shelby would be sufficient
Old 08-27-2007, 03:06 PM
sactown
sactown's Avatar
that never even crossed my mind DUH!
sactown is offline
Quick Reply: Cooling System Upgrade
