spark plugs
Old 10-24-2007, 04:09 PM
  #21
D_Gusler
D_Gusler's Avatar
Default RE: spark plugs
Are re-gapping these neccessary? I got a set coming in the mail today--will be sprayin a 125 shot of N20.
D_Gusler is offline
Old 10-24-2007, 04:17 PM
  #22
Dex
Dex's Avatar
i'll stick to gapper. too many little problems with my car to worry about a stupid 9 dollar plug
Dex is offline
Old 10-24-2007, 05:11 PM
  #23
drbobvs
drbobvs's Avatar
Yes, in my case it was. They said they come pre-gapped, but weren't.
drbobvs is offline
Old 10-24-2007, 05:33 PM
  #24
fordfanboy
I ♥ Acer
fordfanboy's Avatar
Out of the box they are about a .042 gap which is not optimal. For 6-9 psi, you want to be in the .036-.038 range and for 8-12 psi, you want to be around the .032-.034 range and for over 12 psi, you want to be in the .028 range.
fordfanboy is offline
Old 10-24-2007, 08:35 PM
  #25
06elnr
06elnr's Avatar
what about shooting the juice gap?
06elnr is offline
Old 10-24-2007, 08:47 PM
  #26
Saleen05797
Saleen05797's Avatar
I have gone through 2 sets of HT0's in the last 2 months. Now I moved to Brisk. Brisk makes some that are colder than stock, picked up a set for $125. A lot of people told me a lot of the HT0's come bad right out the box and to ohm check them. Someone had to buy 3 sets before he had one good set of plugs.
Saleen05797 is offline
Old 10-24-2007, 10:50 PM
  #27
Briscoe
Briscoe's Avatar
Stupid question, but what would happen if you had to small of a gap?
Briscoe is offline
Old 10-25-2007, 12:36 PM
  #28
fordfanboy
I ♥ Acer
fordfanboy's Avatar
ORIGINAL: Saleen05797
Sorry but it's not true. If oyu got them from dyno joe, then it's not his fault. They told him they were the same heat range as the HTO's but they most certainly are not! The Brsik will work fine for lower boost levels (but so will the HT1's or stockers so why sepnd the money?) but for 12+ psi - the brisk are no good IMO for any length of time.
And you are correct, sort of, about the HTO's. I'll bet the majority of the problems seen with sets right out of the box are that they weren't gapped properly. If you don't gap the HTO's, then you might as well not buy them.
Old 10-25-2007, 01:03 PM
  #29
PLstang
PLstang's Avatar
+1 on the gapping, I have heard people say they come gapped. I don't believe that to be correct.
In regards to the 12 + psi of boost let me add they don’t work well with a 125 shot either! Check my pictures on the preceding page.[:@]
PLstang is offline
Old 10-25-2007, 04:59 PM
  #30
HaneyMotorsport.Com
Banned
HaneyMotorsport.Com's Avatar
PLstang, I have a couple of questions for you..........was it a dry or wet shot? When the plugs were new out of the box, did the bodies have the "blueing" on them???Do you know what the afr was on the bottle?? To me, looking at the pics, it was way lean. The porcelain is whiter than bone and then the blueing. Sorry to go off topic. Thanks
Casey
HaneyMotorsport.Com is offline
Quick Reply: spark plugs
