Nitrous On 05 gt?
RE: Nitrous On 05 gt?
I've been running 100 shot for a year and no issues. I don't go crazy spraying all the time. I've probably run 40 bottles dry and no issues. I am runningAutolite HT0plugs. I am planning on running 125 soon as I know a few who have run 150 with no issues except 1 (sprayed right out the hole, it pooled and blew his intake manifold and bent his hood). Not that major and wouldn't have been an issue with a window switch or just nothitting the switchtill 3000 rpm. Only thing is I will need a fuel pump upgrade before I up the shot. I hear 100 is about the max on the stock pump.
I need to get a wideband. Once I get one I may give it a shot since you said that. I figure I can run the same tune and I think I will have to back out 4 more degrees of timing from the 100 shot tune if I remember right.
ORIGINAL: iwannagofast
Does the Zex kit come with a window switch? Im planning on getting the kit with tax return just curious what all I need.
The key to running nitrous safely on these cars is all in the tuning and making sure you are running it as safe and efficiently as possible!
-Jeff
Ive been running the 125 shot for about a year with no problems on the stock pump.I was told by Zex that the motor will take the 175 shot if you upgrade the fuel system.They claim the pistons & rods are OK for it.I only heard of one other guy running the 150 shot with a Boosta pump.I was leary of going to the 150shot on the stock pump.ohsixGT,,How many bottles have you put through the motor at a 150 shot?
