bank 1 and bank 2????
Old 10-28-2007, 04:22 PM
moosestang
moosestang's Avatar
Default bank 1 and bank 2????
This is a stupid question, but which one is the passenger side and which is drivers side?
moosestang is offline
Old 10-28-2007, 05:03 PM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: bank 1 and bank 2????
bank one (driver's side of the engine)
bank two (passenger side)
howarmat is offline
Old 10-28-2007, 06:04 PM
ohsixgt1217
ohsixgt1217's Avatar
My bank one is completely ****ed up and pulls 40% fuel.
Just thought id vent because i saw you asked about banks.
end rant.
ohsixgt1217 is offline
Old 10-28-2007, 06:07 PM
hammeron
hammeron's Avatar
ohsix, whatcha gonna do, to solve
your fuel issue
hammeron is offline
Old 10-28-2007, 06:18 PM
ebr
ebr's Avatar
at about what rpm does this happen im having issues with car dumping at about 5600 on the dyno and now comp. is low on bank 2 i think its a head gasket.
ebr is offline
Old 10-28-2007, 06:38 PM
moosestang
moosestang's Avatar
Damn! Is that at WOT or all the time? What are your O2 readings?
ORIGINAL: ohsixgt1217
end rant.
Old 10-28-2007, 08:57 PM
sactown
sactown's Avatar
Both my banks love me because of maxed out visa's.
sactown is offline
Old 10-29-2007, 08:31 PM
ohsixgt1217
ORIGINAL: moosestang
end rant.
WOT it is completely fine.....its really strange. At part throttle or cruising speed is where I get the problems.... i just dont get it.
My a/f is in the normal range, but at steady throttle it jumps around quite a bit which leads me to think it has something to do with the TPS.
It is going in tomorow (tuesday) to get on the dyno and figure out wtf is wrong. Hopefully it is something simple but we'll see. Ill keep you updated.
If anyone else has any ideas chime in, ill throw that at the tuner and have him check because I told him verbally the problem and he has no idea what it could be. FIgure if i go in there knowing the problem we can get it fixed quick.
Old 10-29-2007, 08:44 PM
ChiDiddy
ChiDiddy's Avatar
getting on the dyno wont solve any problems. When your Primary o2 sensor (bank 1) goes out, it will make the car act funny. You seem to have a problem with closed loop operation, which is clearly the bank1's problem. (cruising/part throttle). Replace the primary sensor and see if the problem goes away. I'm 90% sure its the problem cuz i dont know the rest of your setup and whether or not its properly tuned.
WOT is fine b/c when u go WOT, ecu runs in open loop, it ignores the primary sensor readings and runs on the built in maps tuned for open loop. Closed loop depends on primary's readings to keep a/f at 14.7. Since the sensor is pooped, it wont run right.
ChiDiddy is offline
Old 10-29-2007, 09:09 PM
ohsixgt1217
ORIGINAL: ChiDiddy
U are 100% correct with everything you said, and my tuner said the same thing. But we switched the two sensors and still got a bank one reading.... im not sure if that would mean anything though.
So basically I should try getting a new o2 sensor? Because you hit the nail on the head with the problem, lol.
Quick Reply: bank 1 and bank 2????
