these brakes suck!!! what should i replace, CHEAPLY?
#21
RE: these brakes suck!!! what should i replace, CHEAPLY?
Go here<<< https://mustangforums.com/fb.asp?m=4123832
#22
#23
Nothinggood is cheap, relatively chep yes but still not cheap. A Baer GT Plus Kit which includes race quality drilled and slotted 14" 2-piece rotors, stainless steel brake lines,high-performance brake pads,the world class PBR 2-piston calipers withcorrectly sizedtotal piston areaset up for the S197GT's and all new mounting and sealing hardware can be found new for $1,000-$1,400 is this cheap to you?The similar Brembo14"Big Brake Kits with 1-piecedrilled rotors and 4-piston calipers run about $1,900-$2,200 and $500-$800 more for 2-piece Bremborotors. A similar but different Ford Spec'd Brembo 4-piston caliper, stainless steel lines, plain 14" 1-piece rotorsand high-performance brake pads from a GT500 can be puttogether in your own "kit" fromyour local Ford dealerfor about $1,200-$1,500 if you can get a car club discount. But this isNOT thesame caliper androtors used in the regular Brembo kits as sold by Brembo!
HTH!
#24
buddy, take it to ford. mine got heat spots and they resurfaced 'em for free. james told me he went to dot4 and stopped having these problems w/ the crap stock brakes. sidenote: my mother's g35 (non-brembo,but w/ DBS) brakes so much better.of course you have to flush the system to change fluids which is a bitch. i heard that dot4 isnt best for this system, rather the high temp synthetic dot3 is supposedly the best. someone else also reccommended akebono pads, i would definitely get some, those pads are the ****. number one on your list, take the car to sawgrass ford and have em resurface. my car had 19k miles when i had this done by themand u could see the spots in the rotors. i used to top it out around 150ish, and damn did they fade and warp. for the kinda driving im guessing u do, my suggestions are the way to go.
musnicki
09-23-2015 07:11 AM
