aeroforce
RE: aeroforce
They sell them on ebay for $239. I got mine for $230 shipped through a group buy on M0dularfords.com
I highly recommend one, but don't play with it while driving, maybe two would be better. They can be daisy chained together so there is no wiring necessary, that's the best part.
It is like having a scan tool hooked up all the time. I can see if my O2 sensor volts, fuel trims, cylinder head temps, estimated power for both bank1 and bank2, Maf volts, coolant temp, knock retard, timing advance. There is a bunch of other crap as well.
RE: aeroforce
Most of the readings can be taken from the data port....some require using the 2 analog inputs on the gauge itself. It can get air/fuel ratio from the data port but it is only the "narrow band" which is not the best reading, you can hook a "wide band" sensor up with the gauge though and you are good to go. This is what i will be doing with mine
RE: aeroforce
ORIGINAL: Burnsy
come on...bump_spot for aeroforce explanations
