Newbe Question
Old 11-03-2007, 12:10 PM
SanDiego
SanDiego's Avatar
Default Newbe Question
Attempting to remove the oil pan on an 07 GT, I can see I need to either:
1. Lift the engine
2. Drop the tranny (manual)
3. Drop the cross member
Can somebody throw me a bone here and let me know which is the quickest?
I can see no bolt holes to connect my cherry picker to, are there holes that I can place a bolt inot to lift the engine slightly?
My Fox is sooo easy, but this new tech seems to be blocking me at every turn. If I ever get this thing off and the oil return line installed I'll post some pictures of the Turob install.
Thanks for any guidance you can provide
SanDiego is offline
Old 11-03-2007, 05:53 PM
Nuke
Nuke's Avatar
Default RE: Newbe Question
And we're doing this for WHAT reason???
Nuke is offline
Old 11-03-2007, 11:58 PM
nate2953
nate2953's Avatar
AFTER READING HIS POST, i would conclude he is trying to install an oil return line. Now im no genious, but maybe doing that requires the oil pan to be removed. I dunno, not big into turbos and their return lines
nate2953 is offline
Old 11-04-2007, 12:25 AM
hammeron
hammeron's Avatar
i have the oil pan R & R procedure from
the service manual, let me know if you want it
emailed
it has you
lifting the engine slightly
lowering the sub frame
remove pan
hammeron is offline
Old 11-04-2007, 07:01 AM
Nuke
Nuke's Avatar
My bad... (makes note to self: read AND retain...)
Nuke is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Newbe Question
