Max Fuel Pressure?
RE: Max Fuel Pressure?
if you mean with the car running, i wouldn't think
75psi would be too much. i routinely go over 70 psi
WOT and i have 39lb injectors
if you mean with the car not running, i am not sure
Running. I know that all fuel injectors have a minimum pressure (something like 43 psi), I was wondering if it could work against you having too much pressure? Sometimes more is bad.
Well, I have 60 # injectors and more is definitely not bad IMHO. I did have a problem with running a bit rich and my tune had to be changed to fix that. I know Saleen 0607(something like that) had a stumble problem on start up just as I did and it was the O2 sensors that could not get the A/F right until the car warmed up a bit (about 10 min). I read in a different post that his was fixed by doing something with the tune so it won't switch to closed loop/open loop system after warm up for 10 minutes as opposed to 30 seconds. (dont quote me) and it fixed his problem. I actually picked up about 10 more RWHP on the dyno but it was 30 degrees cooler and the humidity was less which makes a difference in HP/TQ. So a tune is everything and I was told the spray pattern is better than the smaller injectors as well. I love this forum and the info it provides!!!!!! Hope it helps J
My concern is only if it is too much. There is a fuel pressure regulator installed (return style system) so turning it down is not an issue.
The O2 sensor is something that I will mention to the tuner to see if it might be an issue with the idle problem that keeps coming up. (high idle)
Yeah, I think we got that figured out. Not giving the O2 sensors enough time to warm up. Gonna have the tuner fix that.
Car would idle sometimes at 1500-2000rpm on startup then go back to normal idle after 1-3 min.
