Saleen SC Vacuum Upgrade Kit?
Old 11-19-2007, 09:27 AM
sevenleaf
sevenleaf's Avatar
Default RE: Saleen SC Vacuum Upgrade Kit?
ORIGINAL: ChiDiddy
A lot of manufacturers knowingly do the wrong things to save face. I know plenty of companies that ignore "new' developments or improvements made by end users or resellers. Not sure what Saleens reason for doing so is. Much like the powerflash, it sucks compared to XCal2 tune, but they still do it anyway.
Why does it work better? from my own applications in the past, tapping the brake booster "works" and is the easiest to get to. But when you're wastegate, bypass valve, or whatever controls your boost level, it is dire to send it the most accurate vacuum/pressure source and not to split it with any major component that requires vacuum/pressure. In this case, its the brake booster. As the JDM site explains, the boost readings will not be absolutely accurate, therefore it will dump or take out an inaccurate amount of fuel per volume of air.
Just my own thoughts, but I find it hard to beleive Saleen would do something that will harm their cars. Does the upgrade improve performance or HP of the car?
sevenleaf is offline
Old 11-19-2007, 09:36 AM
ChiDiddy
ChiDiddy's Avatar
I dont think its the manner of it actually harming the car, more like making it more efficient. Also, a tiny bit of insurance.
ChiDiddy is offline
09-17-2015 07:32 PM
TfcCDR
09-14-2015 12:08 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
vintageaion
09-08-2015 10:45 AM
TimeLord101
09-04-2015 09:27 AM
Quick Reply: Saleen SC Vacuum Upgrade Kit?
