WTF engine fail safe??? need help!
ok it started about to months ago and only on cold cold days when i go to start it up for the first time of the day it will run about 1 min and then it comes on and kills the car .. i really need help fixing this problem without taking to the a holes to ford ..
RE: WTF engine fail safe??? need help!
it wonte do it now it did it like 5 times this morning then its fine ..has anyone had it say this before?? is it due to cold air and the lack of back pessure?
i doubt it, either could cause failsafe if the install wasnt done correctly or the rear O2s are turned off, but i think brent would have done that and i am pretty sure the tune is correct for the CAI
But without the codes there are a ton things that cause the fail safe mode.....next time it does it pull the code immediately
