Short throw shifter install
RE: Short throw shifter install
Nothing if you are a little mechanically inclined! Here is Tacobill's write up.
https://mustangforums.com/m_3000094/tm.htm
Good Luck
Good Luck
True dat goody! you def can do it, i believe anyone can, the hardest part is pulling the stock shifter, and putting in the new, otherwise everything else is a breeze. If you got a buddy with tools I would say a 12 pack otta do it. If not, I would say no more than $100, as it may take a little over an hour.
Great choice on the shifter! Its the ***** out best [8D]
Maty - I'd just recommend putting some masking tape or something on the e-brake handle when you take the console off. You could scratch it slightly if you wrestle with the console too much.
Do it yourself - and use tacobills write-up instead of the one's supplied (no pics). It really is pretty easy if you have the basic tools on hand.
09-03-2015 07:14 PM
