Help! Whippled stang running dangerously lean!
RE: Help! Whippled stang running dangerously lean!
well i would not be to worried. i have a turbo'd sentra for over 2 years and at idle and crusie i get 14.6-15.3 afr with a lm-1 unit. now when i punch it i get more like 10.5 afr that i have tuned it for. i have over 20k on the engine and every thing runs fine. i would imagine this would be fine as well. what o2 sensor (wideband or just one off the stock o2)are you using? i know with the lm-1 i have to resest or calibrate it like every 3k miles or so. with out knowing what it does under more throttle or wot there is no way to truely know if you are running lean when it matters.
Haney-I double checked the fuse that I tapped. It's definitely a switched 12V and remains hot during cranking. I could take a picture of the fuse panel and circle the one I used if you ever need it for anything.
Green-I have the autometer ultralite wideband that comes with its own dedicated bosch O2 sensor.
Moose-I'm waiting until my lunch break at 2am (I work nights)to take her out for a bit and attempt WOT.
Everyone-Thanks for the advice!
Sorry cant help with the poblem but you can help me ,I have been trying to find out where to connect the brown wire for WOT . Where is yours connected?
Hey Nails,
OK boost on mine is at -20 at idle. and goes up when on the pedal up to obviouslly 10 lbs when on the pedal hard. Mechanical Gauge.
As for my Dynojet wide band AF set up. It will atay around 14-15 cruising around and at WOT it should be at 12 which it is. I was told it under WOT it goes HIGH like say 18 get off quick cause I would have some kind of problem. Also MY AF gauge has a warning light I am going to download the program from Dynojet to the Dynojet Wideband so a Warning light will come on if it goes to a bad range. Hope this helps some.
ORIGINAL: ebr
Tassy-Thanks for the info man. My A/F is hovering between mid-14 and mid-15 during normal driving. I'm going to open the car up in about an hour to see where it's at under WOT. I'll report back when I do. My A/F gauge has the warning light also, but it's programmed to kick in at about 15.4 from what I've seen.
ORIGINAL: TASSY5
Well, I opened it up for a bit a little while ago, and everything seems OK. If anything, I'm running too rich. My boost got up to about 10.5 PSI, my fuel pressure reached about 73 PSI, and my air/fuel leveled out at 10.9 during a WOT run through third gear. Can't wait to get this sucker dynotuned...
ORIGINAL: nineinchnail1024
Just some thoughts.
You know after seeing Nineichnails afr if you could get the stock FRPP Whipple tune on a X Cal 2 (which should be possible) from a tuner and you have a good wideband AFR gauge installed. We could improve on the stock tune very easy. I mean we seen guys dyno at 410 rwhp with the Whipple stock tune, so just leaning out the fuel with the X cal and using a wide band ( to setup the afr)we could very easy improve that rwhp to around 440 rwhp from a 410rwhp baseline.
The Whipple stock tune runs 19* timing already so just by leaning the fuel with the X cal 2 and using the wideband to get the afr to 11.4-11.6 should produce the above results with no problem imo.
ORIGINAL: TJ
Just some thoughts.
You know after seeing Nineichnails afr ifyou could get the stock FRPP Whipple tune on a X Cal 2 (which should be possible) from a tuner and you have a good wideband AFR gauge installed. We could improve on the stock tune very easy. I mean we seen guys dyno at 410 rwhp with the Whipple stock tune, so just adding fuel with the X cal and using a wide band ( to setup the afr)we could very easy improve that rwhp to around 440 rwhp from a 410rwhp baseline.
The Whipple stock tune runs 19* timing already so just by increasing the fuel with the X cal 2 and using the wideband to get the afr to 11.4-11.6 should produce the above results with no problemimo.
Just some thoughts.
