SPEC Clutch and Flywheel?
RE: SPEC Clutch and Flywheel?
ORIGINAL: moosestang
What exactly causes the clutch to chatter or shudder? Surely you don't have to spend $1k on a clutch to avoid chatter.
ORIGINAL: nineinchnail1024
I've got over a thousand miles on my Spec II and I still get clutch shudder at low RPMs in 4th gear. If I could do it over again, I would have bought the Mcleod.
To answer your question, lots of things can cause clutch shudder. Dirt or oil on the flywheel surface. (Which I know wasn't there because I cleaned the clutch plate and flywheel with acetone immediately before I assembled them together.) Improperly surfaced flywheel. (I had my flywheel resurfaced by a well respected machine shop while I had my tranny out.) It could be a multitude of problems.
ORIGINAL: exx1976
You've been posting an awful lot in the 05-08 section lately.. Did you get a new car?? Just wondering, I mean, they aren't exactly the same car..
ORIGINAL: godminus1
Chris, what grade is your K-80?
I'll be installing the spec stage 2 with their steel flywheel in 2 weeks. I'll be sure to post the results and i'm doing a how to with pics in hopes to get $100 back from amercian muscle.
i have the spec 3+ with fidanza flywheel. when the car it warmed up there is not a whole lot of"shutter"
When you go for performance you need to realise youre giving up some comfort.
Well don't replace it with a Ram clutch because they say right on their website that their performance clutches will chatter. They also told me the stock flywheel wouldn't work with their performance series clutches because of the friction material used.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
