A How To: changing manual transmission fluid
Old 10-24-2011, 03:04 PM
  #111
superslow86
superslow86's Avatar
So has anyone ran in to any issues using the RP Synchromax in the tranny? I am thinking about changing my tranny fluid this weekend as I come up on the 60k mark and was debating on using RP.........Thanks!
2006 GT
superslow86 is offline
Old 12-24-2011, 03:26 AM
  #112
robs
robs's Avatar
Good thread. Just did all 12 pages.
So.
Ford Manual says Mercon ATF, not Mercon V
Tremec says Mercon (not sure ATF or V) or Mobil 1 ATF. Says NO to Royal Purple, but mainly I gather it's due to lack of testing.
Posts on Mobil 1 ATF go from basically "don't notice a difference" to one individual that said it sucked.
Posts on Royal Purple were all positive. One individual stated they had 100k on it. Results were "about the same" to "awesome".
Orileys' computer at the store says Royal Purple ATF. Royal Purple's website says Sycromax.
The guys here that seam very race oriented all say Redline D4 ATF.
Couple say Amoil is the bomb.
Ok. I'm confused. WTF?
I'm leaning towards Royal Purple Sycromax or RedLine D4. Any other long term users?
Here's my set up I just made for getting oil into the tranny. Using pressure sprayer (like for yardwork) would be simpler, but this way all the messy stuff stays inside for garage storage.... Will simply use light pressure from the compressor to "push" oil into tranny, diffs, whatever...
robs is offline
Old 12-28-2011, 08:39 AM
  #113
speedycpu
speedycpu's Avatar
So.
I only have a few hundred miles on my manual 06 GT with the Royal Purple Synchromax, so far so good. It had 59k miles when I got it and now that it was getting down into the 30-40F range I noticed shifting was a little harder, notchy, etc. I after the Synchromax it was super smooth, I really am surprised. Cold start, warm, all smooth.
It reminds me of when Richard Hammond & Clarkson on Top Gear are complaining about American transmissions feeling like trucks, hard to get into gear, etc. and then (I think it was with a Porsche Carrera GT) pushes a supercar's shifter into gear with one finger. That's how it feels now with the Synchromax.
speedycpu is offline
Old 12-30-2011, 08:33 AM
  #114
CaptainOblivious
CaptainOblivious's Avatar
Default Still Going ...
The thread that is. Using the advice in this thread I changed the transmission fluid in my 2008 GT with a TR3650 5-speed manual and stock shifter.
I have a couple of tips to offer others who, like myself, may not be up to speed on how to get to the point where this thread starts.
1. Raise car with floor jack and jack stands. Go to this thread to see locations of the floor jack and jack stands.
http://forums.themustangsource.com/f...n-rear-482388/
2. Remove the shift ****, shift boot and dust boot to get the tubing down through the cabin floor - got to 56 second (or 1 minute) mark of this video:
http://www.youtube.com/watch?v=xaH3h...layer_embedded
Good luck - it worked for me.
CaptainOblivious is offline
Old 02-05-2012, 09:23 PM
  #115
robs
robs's Avatar
Went with Amosoil...
Pressure set up worked easy and well
http://www.youtube.com/watch?v=RvSxO...ature=youtu.be
robs is offline
Old 02-20-2012, 04:12 PM
  #116
manuel86it
manuel86it's Avatar
i am confused too about the right fluid..
here in Italy it's quite easy to have Royal Purple products (plus we build cnc machinery and RP also supply oil for them), but for our TR3650 manual transmission (mine is a 2010 gt) it seems i can use both the synchromax or a 75W-90 max gear from Royal Purple.
i don't get the difference between these two product, except from that in technical sheets synchromax is more correct for automatic transmission, but it looks like many of you use this in manual transmission. so what's your advice? i want to gain smoothness in changing gears, so i'm looking for changing the fluid.
thanks!
manuel86it is offline
Old 02-26-2012, 08:41 PM
  #117
NCEDMD
NCEDMD's Avatar
Default Plastic cap in transmission - Oops!
So I did something stupid today while trying this out. When opening my Royal Purple Synchromax transmission fluid, I used the pointed yellow cap on the bottle to puncture the paper seal over the top of the squeeze bottle. I then proceeded to pour the transmission fluid into my tranny as described above, only I used a funnel attached to the plastic tubing instead of attaching the tubing directly to the bottle top.
Only after finishing the job did I realize that one of the little yellow plastic caps that is supposed to be used to recap the squeeze bottle after you cut the top is missing. I am fairly certain it fell into the bottle when I used it to puncture the seal and was then poured into the transmission. I drained all the new fluid into a clean container but the little plastic cap did not come out. I ran the same fluid (all 4 quarts) through the transmission again - still nothing came out.
Am I the first person stupid enough to do this? More importantly, if that little cap is still in my transmission will it cause any damage? I have not driven the car yet.
Thanks in advance for your help!
NCEDMD is offline
Old 03-24-2012, 03:42 PM
  #118
washburn085
washburn085's Avatar
Changed mine to RP syncromax. I only jacked up the front and was only able to get 2.8-2.9 quarts back in. The short test drive I took felt good. Did this at the same time as putting in a MGW short throw, so hard to really tell the difference, but no issues with shifting that I had with the stock fluid.
When I took out the fill plug, fluid came out. So I lowered my stands to one less notch (the lowest in which I could fit under). I then put the rest of the 3rd quart in and just pulled the tube out and put the fill plug in as quick as I could so much fluid couldn't come out. About 0.1 quarts came out of the tube.
If I notice any rough shifts, I will just go get another set of stands and check the level that way.
washburn085 is offline
Old 03-24-2012, 06:25 PM
  #119
moosestang
moosestang's Avatar
I wouldn't worry myself to death about it. You may have just misplaced the cap. At any rate, the transmission will chew that soft plastic up with no problem. :^)
moosestang is offline
Old 06-18-2012, 12:41 PM
  #120
6xStang
6xStang's Avatar
Thanks for the write-up (4 years ago, LOL). I did mine this weekend; went with Mobil 1 ATF. The old fluid (2006 GT, 20K miles) really looked like crap. I noticed a small, but noticeable, improvement in shifting smoothness.
BTW I did not trust myself to run the tube up through the shifter without making a huge mess inside the car. I just ran a 3.5 or so foot extension on the transfer pump, poured 4quarts into a clean gallon container, and pumped 3 quarts or so in from the gallon container while I comfortably sat next to the car. Once about 3 quarts were in, I got under the car and did the last 0.2 or so from under the car.
Not too messy. The CTS-V is next on my list for this chore....
6xStang is offline
Quick Reply: A How To: changing manual transmission fluid
