A How To: changing manual transmission fluid
Old 03-29-2015, 01:45 PM
  #141
Camster
Camster's Avatar
Not having an easy,safe way to get the car up in the air and level,I put my 04 GT on ramps,drained it,pulled the shifter and poured 3.2 quarts into the top.
Camster is offline
Old 05-08-2015, 05:21 PM
  #142
dmdziad7
dmdziad7's Avatar
Default Removing Fill and Drain Plugs
You will need to use an hex key/allen wrench to remove the fill and drain plugs.
Not sure for other years but the 2012 GT's called for 2.75 quarts.
As always, check your owners manual before hand.
Overall, pretty easy job. Others have complained about using a pump. I used a transfer pump and had absolutely no issues. Only took 5 minutes to refill. Secret is to place the oil higher than your trans so it siphons properly.
I changed mine at 30,000 miles and the oil still looked pretty good. I decided to stay with the full synthetic Motorcraft. Shifting definitely feels quite a bit better. Therefore, although the oil didn't look bad I will change again at 60,000 miles.
Let me know if you have questions!
dmdziad7 is offline
Old 05-08-2015, 05:23 PM
  #143
dmdziad7
dmdziad7's Avatar
Great thread/instructions!.
For my 2012 GT I needed to use a hex key/allen wrench to remove the fill and drain plugs.
dmdziad7 is offline
Old 12-09-2015, 11:18 AM
  #144
06StangLou
06StangLou's Avatar
Hi, new poster here
Just to confirm, it looks like the gearbox fluid change is doable from under the car right? I ask because I have access to a lift and don't want to mess with the interior. I have a V6 and manual box with a bit of noise when it loads up, I am hoping that the RP Synchromax will hell quiet the noise.
Thanks
Lou
06StangLou is offline
Old 12-09-2015, 04:30 PM
  #145
bl817
bl817's Avatar
NOOOOOO do not use the RP in your trans. I would recommend Mobil 1 synthetic ATF or something similar to OEM recommended fluid. Redline ATF is also good. do some searches and read up. RP will eat the synchros over time, as stated by multiple users and trans ppl. 3.2 quarts to the bottom of the fill hole and your good to go. its very simple to change the fluid from under the car. 3/8" ratchet and small extension will remove the plugs no problem. remove the fill plug first just in case its troublesome, then the drain plug. have catch can ready as the fluid is really thin and splashes everywhere, it smells horrible as well. I used a pump to fill once drained. good luck
bl817 is offline
Old 12-09-2015, 04:40 PM
  #146
06StangLou
06StangLou's Avatar
Thanks for the reply and the confirmation of access.
ATF in a noisy manual box? RP says Synchromax is compatible with yellow metal. I've read on various threads here that RP is doing fine in their manual boxes, apparently you don't agree. Another not is the car has 100K miles and I plan to upgrade soon so at this point I am trying to quiet the growl under load. Box shifts fine, doesn't grind or jump out of gear.
Opinions? Looking for feedback.
Old 06-03-2016, 12:43 PM
  #147
Stoenr
Stoenr's Avatar
How are the guys going that used the RP Syncro fluid doing?
Stoenr is offline
Old 06-04-2016, 11:59 AM
  #148
monovitae
monovitae's Avatar
I put RP ATF in mine at 7k and I'm at 65k now about five years later. Run about 10 auto X events a year. Been fine.
monovitae is offline
Old 06-06-2016, 09:55 AM
  #149
Goldenpony
Goldenpony's Avatar
I put AMSOIL ATF in my '06 GT 5 speed trans. Works great.
Goldenpony is offline
Old 06-26-2016, 07:54 AM
  #150
Norm Peterson
Norm Peterson's Avatar
I've been using the Mercon in mine with no issues, and there's a fair amount of road course use involved.
It's easy enough to change even if all you have is jackstands. You can fold a narrow strip of paper 90° and use that as a gauge for setting the fluid to 1/2" below the hole.
Norm
Norm Peterson is offline
Quick Reply: A How To: changing manual transmission fluid
