A How To: changing manual transmission fluid
Old 02-14-2009, 08:26 PM
  #31
vasman
vasman's Avatar
Smile
Just did the change to RP 29600miles. I feel the difference on my stock shifter. A lot smoother particularly on 1-2nd change, which had been my most stiff change. Thanks a lot for the advise and the tips. It really made a world of difference.
vasman is offline
Old 02-25-2009, 12:28 PM
  #32
FixFalcon
FixFalcon's Avatar
Originally Posted by wasvette
Just did the switch last night to RP Synchromax at 133,000 miles on the '06 Mustang GT manual tranny.
133,000 miles on an '06?? Good Christ. My '92 Probe just hit 155k a couple weeks ago, lol. Can this method be used on an SN95?
FixFalcon is offline
Old 04-30-2009, 08:37 AM
  #33
degeze
degeze's Avatar
Changed mine out to RP Synchromax yesterday (car has 61,xxx) and the first thing I noticed was a quieter tranny. I noticed the temperature is down too. The tip using the tubing was a BIG help...thanks moosestang .
degeze is offline
Old 05-07-2009, 08:48 PM
  #34
Menace
Menace's Avatar
Is there a transmission filter to change too???
Menace is offline
Old 05-20-2009, 10:24 AM
  #35
ym42
ym42's Avatar
Smile
Just changed the transmission fluid to Mobil 1 Synthetic ATF, at 55k miles. Thanks to this thread it was very simple and took me about 45 minutes, I was in no rush. The old fluid was very dark and at the beginning looked more like a used motor oil - I am glad I changed it. Talking about the shifts - they do SEEM a bit easier and a bit faster, but its not a dramatic difference. However, my guess that it will be more pronounced in cooler night temps of fall or spring. I already noticed how much the shifts improved when the temperatures hit 60s in the summer, and that was the stock fluid... Thanks everyone for posting!
ym42 is offline
Old 06-21-2009, 06:32 PM
  #36
Menace
Menace's Avatar
I did mine today, I'm at 35800 miles or so, I'll call it 36k. Fluid was almost clear, not red.
Edit: I couldn't get the torque wrench up on the fill plug, so I just guesstimated... we'll see how that works!
Menace is offline
Old 06-21-2009, 07:41 PM
  #37
moosestang
moosestang's Avatar
Good'n tight is fine for the plug, unless you are Arnold Schwarzenegger.
moosestang is offline
Old 06-22-2009, 10:52 AM
  #38
06stangGT
06stangGT's Avatar
how much fluid should I use and how often is the filter replacement needed ?
06stangGT is offline
Old 06-22-2009, 05:32 PM
  #39
moosestang
moosestang's Avatar
filter?
Old 06-22-2009, 08:30 PM
  #40
06stangGT
06stangGT's Avatar
Originally Posted by moosestang
filter?
sorry i have a chrysler DD and i did a tranny fluid and filter change on it.
does the S197 have a tranny fluid filter
if not, i can get RP and have a drain and fill done for under 60 bucks where i work
Quick Reply: A How To: changing manual transmission fluid
