A How To: changing manual transmission fluid
#53
It will most likely puke excess oil out the top breather tube if you over fill it. Not sure if it will cause a problem, but why not slowly fill it until you can feel oil through the fill hole with you finger.
#55
Well that's how I filled the rear end. It will just puke it out the breather, probably won't hurt the transmission, but I wouldn't risk hurting the trans.
#57
i used one of these pumps when i did mine it was $13 at home depot, originally bought it to pressureize the oiling system when i built the motor. it worked great and was real easy with no mess,just filled it up with what i needed, pumped it up and pulled the trigger. i also swapped my stock fluid for royal purple, and since doing so i have not had a sceond gear grind.
#59
Why does Ford recommend filling 1/2" below fill plug and TREMEC recommend filling up to the fill plug
http://xpower-sv.co.uk/images/TR-365...ice_Manual.pdf
page 8
page 8
#60
Do you need to change the transmission fluid on an 05+ GT? I haven't gotten under my car in a while but somebody told me that you can't change the transmission fluid. There is no dipstick or anything. Anybody care to verify?
