Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2014 Mustangs > GT S197 General Discussion
Sign in using an external account
Register Forgot Password?
Search
Welcome to Mustang Forums!
Welcome to Mustang Forums.
A How To: changing manual transmission fluid
Old 06-18-2012, 03:50 PM   #121
moosestang
Vehicle: 2006 mustang gt
Quote:
Originally Posted by 6xStang View Post
Thanks for the write-up (4 years ago, LOL). I did mine this weekend; went with Mobil 1 ATF. The old fluid (2006 GT, 20K miles) really looked like crap. I noticed a small, but noticeable, improvement in shifting smoothness.
BTW I did not trust myself to run the tube up through the shifter without making a huge mess inside the car. I just ran a 3.5 or so foot extension on the transfer pump, poured 4quarts into a clean gallon container, and pumped 3 quarts or so in from the gallon container while I comfortably sat next to the car. Once about 3 quarts were in, I got under the car and did the last 0.2 or so from under the car.
Not too messy. The CTS-V is next on my list for this chore....
I'm still driving on that same synchromax 4 year later.
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP k springs, Pypes mid mufflers, hurst, frpp TB, 4.10's, spohn lca's, adj. UCA, relo brackets, 1 piece DS, spec stg 3+ clutch. 12.52@117.6mph so far with a 2.01 60 ft time
Pumpkin jacking addict
moosestang is offline   Reply With Quote
Old 06-19-2012, 11:17 AM   #122
RedFire281
I'd like to thank everyone who contributed to this thread. I did my tranny fluid change over the weekend and decided to use the Mobil 1 ATF based on much of the inputs. I just moved to the high desert here in SoCal and the annual temps range from freezing in winter to the 100's in summer so the M1 ATF seems like a good year round fluid. Thanks especially to moosestang for the writeup which took all the mystery and trepidation out of the task.
__________________
06 GT Redfire Manual. Saleen SC. Custom Predator tune by Adam @ ST Motorsports, San Bernardino, CA.
RedFire281 is offline   Reply With Quote
Old 12-28-2012, 05:04 PM   #123
supared
Vehicle: 2008 Ford Mustang GT
Lot's of information here, albeit confusing for some folks. I have gathered a lot. I don't see any complaints on this forum or on the web of RP Syncromax harming tranmissions, but apparently Tremec has a preference for Moblil. Maybe the tech guys are told that is all they can recommend.
Personally, I am going with the Red Line D4 ATF ("Our most versatile ATF, use where Dexron III®, Dexron II®, Mercon® and Mercon V® fluids are recommended, provides a GL-4 level of gear protection").
I'll maybe come back and comment on the improvement. I will say that if you are pulling hard, 3rd gear misses are likely because of the tranny and shifter design since they don't mate up directly but the shifter is hanging back and connected to the tranny by a rod (in laymen's terms). The tranny moves around with the motor between shifts, which can play tricks on the mind and make it difficult to thread the needle for 3rd. I am planning to go to some stiffer motor mounts next hoping that also improves the shifting to 3rd.
supared is offline   Reply With Quote
Old 12-28-2012, 05:29 PM   #124
Goldenpony
Goldenpony's Avatar
I recently changed the man. trans lube in my '06 GT. I put in Amsoil Multi Vehicle ATF. Amsoil products are hard to beat.
__________________
2006 Premium GT Convertible
Screaming Yellow, Black Top
Michelin Pilot Super Sport tires
18" "Fanblade Wheels"
CORSA Performance exhaust
Brenspeed 87 octane performance tune
MGW Shifter
Goldenpony is offline   Reply With Quote
Old 12-28-2012, 05:55 PM   #125
moosestang
Redline makes some good stuff. CHE torque limiters on the transmission will help limit the movement of both the motor and transmission. Mine pretty much jumps into 3rd all by itself.
__________________
Old 03-25-2013, 11:55 AM   #126
Whitestang41791
Vehicle: 2009 mustang gt
a real interesting read! 12 pages later, and due for a transmission fluid change..... and im still not certain what fluid im going to use! LOL
Whitestang41791 is offline   Reply With Quote
Old 03-25-2013, 12:27 PM   #127
AutoXRacer
AutoXRacer's Avatar
Vehicle: 2008 Stage 3 Roush Mustang
Quote:
Interestingly enough, after being a hardcore Redline Oil user, on my new T-56 Magnum XL transmission, the Redline Oil was not a wise choice!! During cold operation, the transmission did not want to shift.
I drained the oil and replaced it with Mobil 1 ATF and OMG what a difference!! Cold operation is nice and smooth. I have rediscovered my transmission!!
Long story short, use Mobil 1 ATF. It works!!
__________________
ROUSH
Detroit Muscle | Refined
600HP/580TQ (14-16 PSI) | 640HP/620TQ (15-18 PSI) | 91 octane - Tuned by LITO
AutoXRacer is offline   Reply With Quote
Old 03-26-2013, 07:59 PM   #128
StangLife
Former Sponsor
Vehicle: 1993, Ford, Mustang
If you have compressed air:
Cut hole in cap big enough so that your fill hose fits TIGHTLY. Push the fill house in so that it's submerged and almost to the bottom of the bottle.
Poke a second, small hole into the top of the bottle somewhere above the fluid level. Use your compressed air gun in that second hole to create a slight pressure. The fluid comes out FAST, so be ready!
I've done this on rear ends and transmissions, no problem. It's nice that you can do it from under the car (the fluid will travel upwards due to the pressure) and you don't risk spilling anything inside your car.
StangLife is offline   Reply With Quote
Old 05-07-2013, 11:36 AM   #129
TheStigSC
TheStigSC's Avatar
Vehicle: 2006 Ford Mustang
Seth Laidacker ReverendStang Philly2Pixburgh
Hmmm, I drained mine completely the other day and put in RP Max ATF. It took about 3.5 quarts, maybe a little more, before it started running out of the fill hole. I did it with a pump that is sold as a fuel siphoning pump. Worked very well.
__________________
2014 Candy Blue Ford Focus Titanium
2006 Vista Blue Ford Mustang GT SOLD!
-Kenne Bell 2.6l Intercooled Supercharger
-Lowered on Ford Racing Suspension (Shocks, Springs, Front and Rear Anti-Roll Bars)
-Roush Lower Control Arms
-Ford Racing Headers and Full Exhaust
-Hurst Short Shifter
Check out my photography!
Seth Laidacker Photography
Hi-Res
YouTube Channel
TheStigSC is offline   Reply With Quote
Old 05-07-2013, 06:12 PM   #130
SikO7GT
So after reading all 12+ pages i'm leaning towards the Mobil 1 synthetic atf.
Seems like the RP is more towards warmer climates since it shifts better when at higher temperature. Mobil 1 is said to shift good at all temps. And i live in Nevada where we have -10 F winters to 110F summer and my mustang being my daily driver i think the Mobil 1 suits my needs a little better. If this was my summer car i'd probably go with the RP.
I also changed my PS fluid with Mobil 1 atf and i feel it's a good fluid for that too.
__________________
07 Performance White GT
SikO7GT is offline   Reply With Quote
Old 01-30-2014, 12:15 PM   #131
GCCBrian
Vehicle: 2006, Ford, Mustang GT
@blahdo_s197gt
I'm running into some trouble here and I could use some help. I've tried taking the filling plug off first but for some damn reason it's just not coming off! The car is 8 years old and has been garaged its whole life, it only has 38,000 miles. This i the first time it's ever going to get changed. I've even tried using a breaker bar and it's just not coming off. Can anyone suggest an alternative way to getting this thing off?
The transmission is the TR3650 off the 2006 Mustang GT
- Good thing I went for the fill plug first because if i drained it and couldn't get the fill plug off I would've been screwed
GCCBrian is offline   Reply With Quote
Old 01-30-2014, 05:54 PM   #132
AutoXRacer
AutoXRacer's Avatar
The plugs have treadlock on them, so it will be tough to break the torque, but it should not be that hard. You should be using a 3/8" breaker bar to break the torque, then just a ratchet.
Here are the instructions on servicing: http://iihs.net/fsm/?dir=289&viewfil...%20Filling.pdf
__________________
ROUSH
Old 02-12-2014, 06:31 AM   #133
OutlawFirebird
Vehicle: 07 gt
OutlawFirebird OutlawFirebird
Just switched fluid a few days ago. I put rp ATF instead of Synchromax. Feels smother compared to the stock motor craft. First tyranny fluid change at about 32k. I used a pump my dad had in his tool box. Worked really well a few Pumps on each bottle and it was done. I'll snap a picture of it sometime. He helped which made it easier. Also used a lift to do it. Good tread lots of info here.
OutlawFirebird is offline   Reply With Quote
Old 06-17-2014, 12:36 PM   #134
pairof11s
pairof11s's Avatar
Vehicle: 2011
newbe here, i got a 2011 gt, what trans does it have and does it have the same fill and drain as some of these pic's show?
thanks
__________________
2011 GT CONV. premium package, candy red, black interior with black/cashmere seats, rear back-up camera, 6 speed, GT500 mufflers
pairof11s is offline   Reply With Quote
Old 08-21-2014, 08:22 PM   #135
Ponyboy72
Ponyboy72's Avatar
Vehicle: 2008 Mustang GT-Chiropractor's Edition
Did you take out the driveshaft in order to gain access to the fill plug? The picture shows what looks to me like the tailshaft yoke bolt up plate...?
Be awesome if you can get back to me asap...latest mod will be this gearbox fluid change asap!
Ponyboy72 is offline   Reply With Quote
Old 08-22-2014, 06:18 AM   #136
OutlawFirebird
Vehicle: 07 gt
I did not have to remove my driveshaft when doing my 07gt. I used a pump, to pump the oil in. That's what some use or some run a hose up through the shifter into the cab. I used one like this. http://www.amazon.com/gp/aw/d/B0043YIFGU?cache=779525f80eaa1abcb9a3114b3444b3dd& pi=SY200_QL40&qid=1408706336&sr=1-2#ref=mp_s_a_1_2
Old 02-27-2015, 05:51 PM   #137
66and06stangs
66and06stangs's Avatar
Vehicle: 66 Ford Fastback 06 Mustang Coupe
I've seen several people ask, and if someone answered, I missed it in 14 pages... Are these procedures good for an 06 with a 4.0Liter? I have the std 5 speed, I believe it is the T5. I'm leaning towards the RP (amazon appears to have a sale on it).
A) are these procedures good for a 5 speed in a 4.0?
B) I think RP Syncrhomax is not a bad choice... is it?
Thanks!
66and06stangs is offline   Reply With Quote
Old 03-17-2015, 11:47 PM   #138
Pbreakall
Vehicle: 2005, Mustang, GT
Thanks for the awesome post!!!
I followed these instructions yesterday, it was very simple. I was able to use a car lift, and just used a pump to fill up the transmission once it was drained. I used 3QTS of Mobil 1 ATF fluid.
Click the image to open in full size.
Pbreakall is offline   Reply With Quote
Old 03-25-2015, 02:45 PM   #139
66and06stangs
I'm still looking to do my 2006 4.0 liter. I'm looking at RP Synchromax. Good? Not good? Going once, going twice....
Old Today, 07:57 AM   #140
CKurello
CKurello's Avatar
Vehicle: 2005 Ford Mustang GT
Send a message via AIM to CKurello
Probably should do this for mine. 80k miles and I don't know if the previous owners ever changed it....and now it's supercharge O.o stock clutch be like no massa, please don't beat me no more
__________________
2005 Procharged Screaming Yellow GT
CKurello is offline   Reply With Quote
Old Today, 07:57 AM
MustangForums
Ford Mustang
Paid Advertisement
05, 08, 2005, 2007, adding, bottle, changing, fill, fluid, gt, manual, mustang, s197, squeeze, transmission
Similar Threads
quick question about transmission fluid change 06stangGT 4.6L V8 Technical Discussions 9 11-02-2009 08:45 AM
Royal purple synchromax in manual transmission...are you running it?... moosestang 2005 - 2014 Mustangs 9 05-12-2008 11:22 AM
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
