Help!! my car is acting like its in protection mode or something like it. help!!
Old 05-05-2008, 04:39 PM
FredTT
FredTT's Avatar
Default RE: Help!! my car is acting like its in protection mode or something like it. help!!
Something has got to be shorting out. Check you JLT installation, unplug and plug everything back in. Look for crossed wires....Did you change the MAF with the JLT? Maybe the wires aren't on right.
FredTT is offline
Old 05-05-2008, 07:28 PM
tk5075
tk5075's Avatar
its all installed correctly, i didnt change the maf, it was directly bolted onto the jlt, and it is still correct.
does anyone know what the dct's mean?
tk5075 is offline
Old 05-05-2008, 09:11 PM
FredTT
FredTT's Avatar
Something is not installed correctly...otherwise it wouldn't be shorting out and blowing fuses. Your dcts are pretty obvious...
[ul][*]p0010- a cam pos actuator cir 1[*]p0020 - a cam pos actuator cir 2[*]p0102 -mas vol ar flo cir lo I[*]p0135 -ox s hir cir 1/i (not sure if its 1 or I) s2[*]p0155 -htd ox s htr cir 2 si[*]p0443 -evap ctrl cir error[*]p0446 -evap ctrl cir error[/ul]Those were all caused by the fuse poping. The fuse controls all of the mentioned failures, and without power...they fail, hence the errors. You need to go back and make sure EVERYTHING is plugged in. Unplug it and replug it. This started happening after you installed your JLT and tune, so something must have gone wrong with the install. Pull it all off and put it all back, change the fuses, reload the tune, and try again.
FredTT is offline
Old 05-05-2008, 09:16 PM
blueherd02gt
blueherd02gt's Avatar
+1
I'd return it to stock... And start over to rule out coincidences
ORIGINAL: FredTT
blueherd02gt is offline
Old 05-05-2008, 09:40 PM
tk5075
tk5075's Avatar
okay guys thanks for the advise, i will give this a try, and ill let yall know ho it goes
tk5075 is offline
Old 05-19-2008, 11:29 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: blike
Fuse 47 is A/C clutch relay, EVAP canister vent control solenoid, EGR system module, Heated oxygen sensors, Variable valve timing solenoid, Inlet Manifold Runner Control module, Automatic transmission, EVAP canister purge valve
Fuse 47 is the Brake Pedal Position Switch, EVAP Canister Purge Valve
and the EVAP Canister Vent Control Solenoid only.
Fuse 52 is the rear defrost relay.
http://iihs.net/fsm/?dir=40&viewfile...bution-SJB.pdf
157dB is offline
djbigskrilla
09-20-2022 01:04 AM
squishbang
01-26-2016 04:58 PM
KEM Motorworks
08-14-2015 10:13 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Help!! my car is acting like its in protection mode or something like it. help!!
