Tensioner pulley dieing! Have some questions...
Old 05-06-2008, 02:28 PM
MC Stang
MC Stang's Avatar
Default Tensioner pulley dieing! Have some questions...
My tensioner pulley is making all kinds of rattling and metallic clicking noises and I am pretty certain it is dieing. I've never changed one of these before, how do you release the tensioner arm? Is a special tool needed? Once the tensioner arm is loose do you just unbolt the pulley, and are either of these reverse thread?
Thanks in advance for any help with this.[/align]
MC Stang is offline
Old 05-06-2008, 02:46 PM
Dex
Dex's Avatar
Default RE: Tensioner pulley dieing! Have some questions...
loosen of the bolt on the tensioner a bit then push it down. You can do it with a rachet extension ro get in there easier.
Dex is offline
Old 05-06-2008, 06:30 PM
hammeron
hammeron's Avatar
1/2 " breaker bar really helps to
move the tensioner arm down,
then you can slip the belt off the
alternator with the other hand
hammeron is offline
Old 05-06-2008, 07:04 PM
exx1976
exx1976's Avatar
My tensioner pulley is starting to squeak on me.. Or maybe it's the idler.. I don't know. Either way, one of those is squeaking. Where can a replacement be had? Is it a dealer only part, or is there anyone who makes a higher-quality aftermarket one??
exx1976 is offline
Old 05-06-2008, 07:30 PM
moosestang
moosestang's Avatar
You need a 1/2 inch rachet with a pipe or breaker bar to attach to the tensioner arm in order to release the tension. Push on your rachet and slip the belt off the alternator. Once you remove the belt you can slowly release pressure on your rachet and then just unbolt the tensioner. 3 bolts, 18 foot lbs when reinstalling it.
How do you know the noise is coming from your tensioner? There's really not much there to fail.
moosestang is offline
Old 05-06-2008, 10:18 PM
exx1976
exx1976's Avatar
I don't know if you were talking to me or the OP, but mine is a squeaking that goes away as it warms up. I've stuck my head under there SEVERAL times when it was cold and listened. It's definitely coming from the passenger side. Beyond that, I'm guessing it's the tensioner or idler, since the only other supercharged S197 around here locally has also had tensioner issues..
exx1976 is offline
Old 05-07-2008, 09:21 AM
MC Stang
MC Stang's Avatar
Moosestang:
Thanks for the advice on releasing the belt tension. I am 90%+ certain that it is the idler pulley because I used an automotive stethoscope to isolate where the source of the noise was coming from while the engine was running. The noise through the stethoscope was much louder from the tensioner pulley, you could actually hear the metal “grating” within the pulley. The other pulleys where much quieter, though the idler pulley was a little noisy, I’m thinking of replacing it also while I’m at it.
ORIGINAL: moosestang
MC Stang is offline
Old 05-08-2008, 08:02 AM
MC Stang
MC Stang's Avatar
I changed the tensioner pulley last night, it was a breeze. Thanks for the help guys it made it easy.
MC Stang is offline
Old 05-08-2008, 08:58 AM
exx1976
exx1976's Avatar
ORIGINAL: MC Stang
WHERE DID YOU GET IT?!?
exx1976 is offline
Old 05-08-2008, 11:26 AM
moosestang
moosestang's Avatar
ORIGINAL: exx1976
ORIGINAL: MC Stang
I don't know if he swapped the stock tensioner pulley or the whole tensioner, but you can actually use a 90mm idler pulley on the tensioner. Whipple has you do this with the 10psi pulley and replace your 90mm idler pulley with the 100mm that comes with the kit. All that does is take up more slack from the belt.
Quick Reply: Tensioner pulley dieing! Have some questions...
