Forged Rotating Kit - DIY? Part 1
#22
RE: Forged Rotating Kit - DIY?
mustanghobby, do you think this kit is
the one for our engines and for our goals
phatphil, i'll definately do a write up after
the fact, maybe periodic updates as well
#23
yes, but i'm drawing the line after
the rotating assembly, tensioner,
8 rib kit, and clutch kit
ORIGINAL: MexGT
HP = a lot of coin $$ !! lots of suporting mods everywhere[&:] (learned that recently lol ....)
#24
ORIGINAL: hammeron
ORIGINAL: MexGT
#25
hmm..I've built several 302's in the past but I'm weary of the ohc in these cars. You do raise questions though. Is there a handbook out there with the 3v breakdown in it?
#26
blue, i really just want to install the
rotating assy, then bolt my heads
back on, no fuss no muss....
does anyone see a reason that this
plan won't work
plan won't work
#27
I would not just throw that assemblyin there. You should have the block hot-tanked, freez plugs replaced, check the deck for trueness, balance rotating assembly and more. What about new head gaskets and ARP studs for the heads? Can you mic out the crank and main bearings/rod bearings to ensure proper clearance? If you know how to blueprint an engine then you should be okay.
#28
ORIGINAL: hammeron
plan won't work
plan won't work
