***WHIPPLE CREW MEETING***
#102
RE: ***WHIPPLE CREW MEETING***
Ok thanks, these gauges are starting to become a little pricey but they are worth it if will help with me not blowing the engine. I went with a larger pulley for right now until I can afford internal parts for the engine.
thanks
thanks
#104
hi im a new member just got mine on last night, i put a full tank of gas in and when it got to half a tank it went to empty and said i had 0 miles left. so it died then i put some gas in and ran again then the same thing happened. the only thing that i can think of is a bad gt500 fuel pump. also my milage went from about 23 non f/i to 14 this is a custom tune too, thanks for any help yall can me with.
#105
ORIGINAL: omino1
this is a COMPLETE quess on my part as I too just finished my install today: The two wires you had to take from the stock fuel pump harness and put into the 6 point gt harness were fuel level sensors and maybe you crossed them.
#108
omino1, i believe gas is used from the
passenger side first, so maybe the fuel
crossover tube (inside the tank) came
loose.
You would have to open the fuel tank
access cover (under rear seat) to check
this....
whatever it is, i think it is a simple fix so
hang in there
loose.
this....
hang in there
