New GT info
New GT info
Got my new GT today, I drove around for awhile showing off to all my friends, got home took out my screw driver and needle nose pliers, took off the inlet tube to remove the hc trap, none their, I took the whole tube off not in there. I read that someone else that took recent delivery didn't have one either. Apparently Ford reads this forum and found out everybody is taking them out so they saved money and stopped putting them in lol. Mine was built week of 4/25. Also the fuel tank is the up dated version no problem filling up, the salesman said it took him 20 mins. to fill the older ones up. For those who don't have theirs, you won't believe the driving expreince this thing hauls ***.
RE: New GT info
Welcome aboard cfr!! Congratulations!! It's a helluva car, isn't it?
BTW, I was the one who posted that mine didn't have the vapor trap. And I have had no problems with the gas tank (except it seems to get empty too quick; dam leadfoot - LOL). But, guess what... my CD player started skipping yesterday... not a lot, but every so often. I'm going to keep an "ear" on it and see how it goes for a few days.
RE: New GT info
Hopefully I have the same luck. Mine was built Apr 25, but now the dealer is trying to take me for a ride since there are so many prospects lined up. I really don't think he wants to **** me off, because I will be home in a couple of weeks
RE: New GT info
congrats on your gt cfr865,check your fuses under the hood some people have had loose fuses, I checked my fuses and they was ok. but I had the bad radio and the service manager has me one on order, and I have the bad strut bearings and I am on a waiting list of several hundred people to get them replaced when ford has a solution. no problem with filling gas tank, the prodution date on my 05 gt was 02/05. I hope you have fun showing it off like I did my torch red 05 gt coupe. I still have people that want to look at it when I park it at the malls,etc. I think the new body style is great but I really like the 5 speed auto over the 4 speed auto that I had in my black 04 gt coupe.
RE: New GT info
You might go back and check to verify but...
I am thinking that the Vapor Trap thing might be a California Emissions requirement. If your car is built to meet CER you will have it. If it isn’t, you won’t.
Same with that stupid “Air Pump†they make the CA Cars have.
RE: New GT info
ORIGINAL: RetiredGeneral
I'm in CA and mine didn't come with the H/C Trap... I wonder if early production Mustangs had them but they stopped recently... my build date was 04/05/05.
Rick
Rick
No ash trays in these buggers either... lol.
RE: New GT info
ORIGINAL: red05
https://mustangforums.com/m_496918/tm.htm
RE: New GT info
thanks cmenders, but that tsb is no good anymore it was only a patch and ford has told all ford service departments to stop using that fix until they have a real solution because it is a design flaw. the service manager at my dealership is a close friend of mine and he showed me the letter from ford on this problem and if they used that tsb to fix it ford would not pay for it. and if you start taking the front end apart several times to try this fix you will only cause premature wear on front struts and parts as this fix will not last. They hope to have a real fix very soon.
