New Nitrous Dyno numbers!!
So i just took my06 GTto get dyno tuned by a local shop called Performance Solutions Racing for a safe summer tune. They could have got alot more out of the car but with the heat and crappy 91oct gas here in AZ they made it very safe. My mods are: S&B CAI, PYPES O/R Midpipes, PYPES Violators, DynoTune Nitrous Kit, Spec Stage 3 clutch, Fidanza Aluminum Flywheel, BMR Billit LCA, BMR UCA, FordRacing Springs, and tuned by PSR.
The final dyno numbers are
Bottle: 430whp and 561wtq!!
N/A: 298whp and 318wtq
The bottle numbers were also with the bottle only at 800-900psi. I didnt have my bottle warmer hooked up and the pressure kept falling so im sure at around 1000psi i could get some better numbers....So what you guys think?...BTW these numbers are on 91oct fuel and 100 deg. weather
RE: New Nitrous Dyno numbers!!
Man that's Nuts! Maybe I should try them for dyno numbers!
Note my previous post: https://mustangforums.com/m_5287920/tm.htm
I got this done at Dyno Comp in Scottsdale, AZ
Where is Performance Solutions located?
ORIGINAL: whtcanbrwnd04u
Uhm... are you serious?
I have similiar n/a numbers as you... i think i need to look into nitrous asap. What kit are you using and what shot?
ORIGINAL: MacGyverGTP
ORIGINAL: jahudso2
A gain of 200+ ftlbs of torque is insane! Can you post the graphs online so we can see how the curve looks?
