Hesitation Anyone?
Old 05-13-2005, 02:00 PM
mauiboy
mauiboy's Avatar
Default Hesitation Anyone?
On several occations between 1st and 2nd gear and last night between 2nd and 3rd my GT hesitated when I put my foot into it, goofing off with a rice burner. It last for only a second but feels like I ran out of gas and usually happens around corners. Does this 05' have a cut off a 6000 rpm? or do I need to take it in? It only has 500 miles on it... any suggestions?
[IMG]local://upfiles/16389/FC6952483C004014AE1460EF6A79E823.jpg[/IMG]
mauiboy is offline
Old 05-13-2005, 02:02 PM
don_w
I ♥ Acer
don_w's Avatar
Default RE: Hesitation Anyone?
It is my understanding that there is a rev limiter programmed in... I've bumped up against it a few times myself.
don_w is offline
Old 05-13-2005, 02:22 PM
Professor Wizard
MF Moderator
Professor Wizard's Avatar
IF you have the Diablo Tuner you can change the overrev points.
Just thought I would mention that!
Professor Wizard is offline
Old 05-13-2005, 04:29 PM
cmenders
cmenders's Avatar
There is a rev limiter and if you hit it hard you will notice it as the engine will basically only get enough gas to idle and you will be glad you have your seat belt on, tight!
The other posts are correct that if you get a Diablo Predator you can raise this limit. If I recall correctly the stock tune is set to about 6,000. The performance tunes that I have played with all move it up to the 6,500 to 6,700 mark.
cmenders is offline
Old 05-13-2005, 04:31 PM
don_w
I ♥ Acer
don_w's Avatar
6,000 sounds about right... that's where mine seems to hit a wall. Guess it's time for that Predator!
don_w is offline
Old 05-13-2005, 04:39 PM
mauiboy
mauiboy's Avatar
Thanks for your help I'll be getting the Steeda CAI and the Diablo soon, this should give me alittle more play in the red. But your right (cmenders) from 2nd to 3rd last night it put me right into the steering wheel... ouch!
[IMG]local://upfiles/16389/5A48CFD71F334B5BBC64B8787F9CA5F1.jpg[/IMG]
mauiboy is offline
Old 05-13-2005, 04:46 PM
firemedix911
firemedix911's Avatar
I don't think your problem is the rev limiter but with a sensor that activates when you r shifting and using the clutch under hard driving conditions. It is programed so that you don't mess up the trany. There was an article on mm&ff on this. They use the xcalibrator to fix this setting. Jus by doing that and a couple more of things. The car ran 12.74 ET I think. I know it was on the 12's. Check it out. It came out like 2 to 3 months ago.
firemedix911 is offline
Old 05-13-2005, 04:53 PM
don_w
I ♥ Acer
don_w's Avatar
Actually, the best run was 12.45 @ 107.92. The list as shown in the mag:
SCT computer tune-up
MagnaFlow mufflers & stainless steel tips
Steeda underdrive pulleys
QA1 rear shocks
FRPP 4.30 gears
MT E/T street tires (26x11.5)
Installed cost = $2,430.
don_w is offline
Old 05-13-2005, 07:48 PM
Z_GT
Z_GT's Avatar
ORIGINAL: mauiboy
Make sure when you recieve your Predator that is has the most recent update file from Diablo.
http://www.diablosport.com/Downloads...20Mustang%20GT
You can find multiple threads discussing throttle lag and other issues due to inadequate software versions on the tuner. The newer versions will make her run perfectly.
Z_GT is offline
Thunderball
15
11-22-2015 11:49 PM
Omgitsa88Stang
10-05-2015 07:33 AM
AMAlexLazarus
AmericanMuscle.com
09-23-2015 01:14 PM
SteelerNation82
09-16-2015 07:11 AM
09-10-2015 08:39 PM
Quick Reply: Hesitation Anyone?
