hey nuke, sometimes FRPP has you look
at the label on the side of the PCM, which
you can only see if you pull the PCM out
i had to do it for my pro cal, also
It was in the directions to get the 12 digit code on the side of the PCM. So was disconnect the battery. I just forgot that small detail by the time I got downstairs to the car.
Time to go to dealer and play dumb....have it towed if needed... JMO
what he said. just tell them you dont know what is going on and that you got a check engine light. do you know anybody that has a sct? you could get the code and see what it is yourself and go from there.
Car is running after sitting with the battery totally disconnected overnight. Thanks for everyone's help.
Unless the stang was
running or the key was
in the run position when
you flipped the levers,
all should be well.
The Adaptive Learning is screwing with you.
Nope, was not on or running at the time of the incident. All appears well. Reset the radio and the TPMS. Will know for sure when it stops raining and I can take it for a ride.....
