JUST GOT MY BAMA 93 RACE TUNE!!
Old 03-08-2009, 08:27 PM
  #51
mbwillis3305
mbwillis3305's Avatar
the bama 93 tune seems popular, anyone have any info on it?...also if anyone has any feedback on the bbk 62mm throttle body i would appreciate it
mbwillis3305 is offline
Old 03-08-2009, 08:49 PM
  #52
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
congrats Adam!
mygt500 is offline
Old 08-20-2009, 06:25 PM
  #53
Chromestang67
Chromestang67's Avatar
Default TB ain't worth it.
I hope this informantion helps you guys. Larger throttle bodies on stock or lightly modified domestics/imports do not yield any gains. You may get 4 hp on a V8 at 6000rpms but lose 10 hp & torque in the midrange all for $200+. Save your money for a high flowing cold air intake with a proper tune. Just a K&N filter on any stock car will yield only 3 hp on a V8 (2 hp on a V6) at redline and you will lose power in the low end. These are my results from working at a low buck speedshop with a dynometer. Usually exhaust mods help with more power but will fall flat if the pipes are oversized (3 in pipes are only for highly modified big blocks) and do not work well on newer cars with cam/valve timing. Trust me I am not a salesman and have seen over 3 dozen import fanantics spend up to $800 for a single 2.25 inch catback and cold air intake for a lousy 2.0 honda that only gives 8 hp at best with the hood up and 2 lb. ft. torque not including the cost of a $400+ tune. Sometimes you mind tells you your car is faster but the numbers most likely do not lie.
Chromestang67 is offline
09-08-2015 06:25 PM
Mustangmalo
09-06-2015 05:22 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: JUST GOT MY BAMA 93 RACE TUNE!!
