Check Engine after reinstall stock Air and Tune
Last night I removed my BBK intake and 93 Brenspeed tune and set the car back to stock for the Winter. On my way to work today I noticed that the Check Engine light was on. Upon opening the hood I realized that I forgot to connect the wire to the sensor near the air box.
I connected the wired, but the Check Engine light is still on. Do you know how many times I'll need to restart the car before it will go away? I tried to restart it like 8 times, but that didn't help.
Should I simply flash back to the Brenspeed tune and then back to stock to clear the light? Disconnect the battery?
Thanks Matt07GT
I did what you said and went ahead and reset it with my Tuner, the code was related to the sensor that I had failed to connect. I didn't realize that the Tuner could actually reset codes, that's great!
inyadreems
08-21-2015 09:10 AM
