Which oil pump for new engine
I found this oil pump from Ford Racing Parts and am wondering if it will cause any problems with the variable valve time since it uses oil pressure. This oil pump, according to the website, increases oil flow by 20 percent.
http://www.fordracingparts.com/parts...KeyField=10213
This pump will go into a new forged short block. I am going with new valve springs in the cylinder heads, so I can take the REV limiter up on the new block to about 7250. Should I go with this one or just use a stock oil pump.
Livernois uses the stock pump on their built SBs, JDM uses the GT500 pump on theirs,
if the motor is properly balanced either should be fine for use. IIRC Livernois has said that they have motors spun to 8000rpm on the stock pump
Whatever you do, get a good unit and don't skimp.
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
