Grannatelli vs bbk /accufab throttle bodys
what is the differance in throttle bodys?..is it just the name 'GRANNATELLI" that makes it 100$ more than bbk or accufab..I have an 08 gt and have flowmasters,k&n cold air and the super chip mod.anyone have any sugg. as to what they would bump up next..ae maf,plenum,I have about 400$ to play with..thankx. Dug
The stock throttle body is as good as the others (or at least not worth the $$ for what little you'll gain minus the headaches that some have come across) unless you go FI. Save the $$.
I've been doing a little research and I'm seeing people with only a CAI/Tune get about 8rwhp gain when going to a GT500 throttle body. Some say it needs a retune, and others say it does not.
Now, for 400 bucks I cant see spending the money - but I may be grabbing a throttle body from a 2006 6.8L V10 today which is supposed to be the throttle body Ford used on the GT500's and it will only cost me 100.00 shipped. I will have to make a small spacer plate (I'm assuming the larger throttle blades hit the inside of the stock intake), but if you have any fabrication skills making a plate with 4 bolt holes and two throttle plate holes should not be a problem at all.
Once I get UDP's I think I will be done in the power improvement area for my car since my wife drives it more than I do, but I will get some dyno numbers at that time.
i wish i had dyno access for some before and after runs, but for 100 bucks im pretty sure it will work out to be a good deal. there was another mustang forum site that i wont link cause they dont like that - but a guy did dyno pulls before and after and got 8hp at the tire.
