No problem at all so far. I actually went through a touchless car wash with it on, and the jets came around and sprayed right in the scoop. I got real nervous there, but nothing happened, drove out just like normal.
It's hard to explain, but there are four drainage holes where the water drains down into tubes and away from the engine. I'll try to get a pic tomorrow. As for the scoop itself, water going into the scoop is prevented from going into the filter by several 90 degree angles in the tubing. The air forces the water against that angle, and it can't make the turn to go further through the tubing. Again, lol, hard to explain.
