Rotating assembly
Old 03-30-2009, 06:53 PM
HaneyMotorsport.Com
Banned
HaneyMotorsport.Com's Avatar
Originally Posted by 2005 white s197
The reason livernois doesn't furnish main bearings is....."YOUR SUPPOSED TO CUSTOM FIT THE MAINS TO THE CRANK BY TAKING MEASUREMENTS YOURSELF"!!!!!!!!!!!!!! Under no circumstances should you use bearings that come with a kit "UNLESS THEY CUSTOM FIT THEM and you have PROOF!!!!!!!!!!!!
The reason is the block! Now, I have not run into any bearing diff. in the 05 up alum blocks. The 96-04 iron ...Windsor and Romero blocks run diff. bearings.......mainly the main thrust bearings.
Ford had/s two styles - one uses a upper and lower 1 pc. flanged thrust bearings, the other has one 1pc. flange and the other side uses a "horse shoe" thrust plate.......
As long as we know what block and year, we can provide right bearings....99.7% of the time
Casey
HaneyMotorsport.Com is offline
Old 03-30-2009, 08:05 PM
hammeron
hammeron's Avatar
all this talk of forging.....
i wish someone would whip up a
Forged rotating assembly, installation guide.....
hammeron is offline
Old 03-30-2009, 09:34 PM
PSUSkier
PSUSkier's Avatar
+1
I'm more curious than anything.
PSUSkier is offline
Old 03-30-2009, 09:44 PM
clfrye
clfrye's Avatar
OK, I got the block from Ford Racing Parts. Its part number is M-6010-A46NA. This is a 4.6l aluminum block machined for 3 valve heads. The stock block for 2005+ Mustang GTs. Which style of thrust bearing does it use?
Casey
clfrye is offline
Old 03-30-2009, 09:47 PM
hammeron
hammeron's Avatar
i would much rather follow someone else's
guide, then to have to write my own....
hammeron is offline
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
foxtrot
09-29-2015 06:32 AM
mltdwn12
09-23-2015 08:54 AM
Mr. D
Suspension
09-20-2015 09:20 PM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: Rotating assembly
