BBK TB troubles
Old 04-27-2009, 07:23 PM
Lankers
Lankers's Avatar
Default BBK TB troubles
I recently installed a BBK Twin 62mm throttle body and a throttle body spacer on my 05 GT. Since I added the throttle body, the car surges all the time. I've not had a check engine light yet. I suspected a vacuum leak, but everything I can see and haven't found anything. The only thing left that I can try is replacing the throttle body gasket (which I have on order) to make sure there's not a leak between the spacer and plenum. Has anyone else installed one of these throttle body's and did you have similar problems? I have an SCT Xcalibrator2 so if there is anything I can do with it to fix the problem, please let me know. Thanks for the help.
Lankers is offline
Old 04-27-2009, 07:29 PM
KLO
KLO's Avatar
Lol, someone didn't poke around on the forums befroe buying one apparently... Just get rid of it...
KLO is offline
Old 04-27-2009, 07:30 PM
BFMacias
BFMacias's Avatar
Get rid of the TB because that is your problem. I had one with the same problems and it is your TB. I think its the weight of the BBK throttle blades vz OEM throttle blades. The BBK ones are heavier and are probably giving you your problems. Truthfully you should not have bought the TB or the spacer. I recommend you read the forums before you buy anything else so the you don't make the same mistakes as others.
BFMacias is offline
Old 04-27-2009, 07:36 PM
Lankers
Lankers's Avatar
alrighty...back on eBay it goes then lol. thanks for the quick responses.
Lankers is offline
Old 04-28-2009, 02:45 PM
goose5
goose5's Avatar
I know this is a bit late but the spacer is nothing more than a paperweight on a non-TBI or carbureated engine. As for the BBK throttle body, i found that when the engine was cold and in open loop it surges but as soon as it was in closed loop it smartened up. Has anyone else noticed this with the BBK 62mm?
goose5 is offline
Old 04-28-2009, 03:02 PM
Nuke
Nuke's Avatar
+1 on not researching this first. Yes, the spacer is garbage. And more people have had issues with aftermarket TB's than just about any other mod that comes to mind. You don't need anything beyond the stock TB unless your aspirated or heavily modded internally where the engine can make use of the extra air flow.
Nuke is offline
Old 04-28-2009, 03:21 PM
157dB
Cut & Paste Expert
157dB's Avatar
"alrighty...back on eBay it goes then lol. thanks for the quick responses."
The leak was the $$ leaving your wallet.
Are you going to unload it on yet another unsuspecting
mustang owner like was done to you?
157dB is offline
Old 04-29-2009, 01:42 PM
kentompkins
kentompkins's Avatar
I installed the BBK throttle body a year ago. No issues whatso ever. NA engine with BBK CAI.
kentompkins is offline
Old 04-30-2009, 01:24 PM
MadMike1337
MadMike1337's Avatar
interesting that some have issues and others dont. i have heard more bad than good which has turned me away
MadMike1337 is offline
Old 04-30-2009, 05:05 PM
BlackS197Stang
BlackS197Stang's Avatar
I've had mine for about a year now, along with a BBK CAI. Mine has never surged, but I did have a problem with hanging idle when coasting. I found a fix on another forum. It worked great for me, and it may fix your problem too. Here's the link: http://www.moddedmustangs.com/forums...-t-body-2.html. It's at the bottom of the page. I didn't reinstall my old TB. I just adjusted the new one while it was on the car and made sure the TPS was in tolerance.
BlackS197Stang is offline
Quick Reply: BBK TB troubles
