Old 10-23-2015, 04:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
how to: computer reset
Old 05-10-2009, 11:05 AM
VN4308
VN4308's Avatar
Default how to: computer reset
How do you reset the computer? Do you just remove the negative battery cable for a bit then reconnect?
VN4308 is offline
Old 05-10-2009, 11:54 AM
BlackS197Stang
BlackS197Stang's Avatar
Yes, but I'm not sure how long is typically necessary. Someone more knowledgeable witll have to answer that. I've left mine off overnight, which is overkill I'm sure.
BlackS197Stang is offline
Old 05-10-2009, 11:57 AM
08GT4U
08GT4U's Avatar
i thought it was the positive not the negative.no wonder mines didnt do anything lol.
08GT4U is offline
Old 05-10-2009, 12:58 PM
VN4308
VN4308's Avatar
I'm thinking it should be 10 min max.......anybody know out there??
VN4308 is offline
Old 05-10-2009, 01:00 PM
08GT4U
08GT4U's Avatar
from what i have read everyone does 30 minutes
08GT4U is offline
Old 05-10-2009, 01:23 PM
One Bad Stang
One Bad Stang's Avatar
i'm assuming you are trying to reset it because your going into the dealer for warranty work and you have a tune installed and your going back to stock. maybe im just lucky, but i left my tune installed and took it to the dealer and they didnt say anything about it at all. all the warranty work was done and have a nice day was all they said.
One Bad Stang is offline
Old 05-10-2009, 02:43 PM
Nuke
Nuke's Avatar
It really doesn't matter if it's the positive or negative cable, as long as you kill power to the PCM. As far as time, I've heard 15 minutes being the shortest interval with 30 minutes being a safe number.
Resetting the PCM will reset the adaptive learning (which tends to cause our Stangs to become less aggressive) while not affecting the loaded tune.
Nuke is offline
Old 05-11-2009, 03:01 AM
One Bad Stang
so as far as the "adaptive learning" thing goes, will loading the factory tune back in and then re-loading the aftermarket tune back in reset the adaptive learning thing?
Old 05-11-2009, 03:54 PM
157dB
Cut & Paste Expert
157dB's Avatar
color=red]It really doesn't matter if it's the positive or negative cable, as long as you kill power to the PCM. [/color]
Not for PCM resetting, But it does matter for safetys sake.
Pulling the positive lead without removing the negative lead
first puts you in risk of danger from shorting
out the wrench to the body thats negative and shorting
out the battery. Also finger rings are a big no no as
if they short the battery thru the wrench, they will get
red hot pronto and burn a ring around your finger.
Negative battery cable, not the positive.
20 minutes to reset computer as per the Workshop Manual.
Reloading tunes does not reset the adaptive learning.
Follow the OwnersManual for the proper re-learning procedure.
157dB is offline
Old 05-11-2009, 04:38 PM
08GT4U
08GT4U's Avatar
157db can you please tell me what is the proper re-learning procedure after the battery been disconnected.i dont have an owners manual.thank you
08GT4U is offline
Quick Reply: how to: computer reset
