Emergency question about reflashing to stock
Old 05-11-2009, 07:53 PM
McTwist
McTwist's Avatar
Default Emergency question about reflashing to stock
Ok, car needs to go in for warranty work tomorrow. The keys won't turn in the ignition so I can use my tuner to reflash it to stock. I've taken my intake off and put the stock one back on.
Here's my question, if I leave the battery disconnected for a little while the car will reflash to stock correct?
Thanks in advance
McTwist is offline
Old 05-11-2009, 08:00 PM
Nuke
Nuke's Avatar
No, it will not. Reinstall your CAI and tell the dealer IMPLICITLY, not to reflash your PCM. Bust his nose if he refuses you warranty work on the ignition switch.
Nuke is offline
Old 05-11-2009, 09:27 PM
One Bad Stang
One Bad Stang's Avatar
i agree with nuke. your CAI/Tune did not cause the key not to turn in the ignition, so therefore, they cant tell you it's not covered because of those things.
One Bad Stang is offline
Old 05-12-2009, 04:50 PM
157dB
Cut & Paste Expert
157dB's Avatar
Take the ignition switch apart and manually turn it to run
to be able to replace the tune with the stock one.
Its pretty simple. You can even fix it yourself while
you have it out and forego the stealership trip and
reflashing of the PCM.
Because of the PATS system, the key switch assembly
is not that protected or that difficult to access and/or
remove/replace in the S197.
Wiring diagrams so you know what you are doing....
157dB is offline
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-02-2015 08:51 PM
09-02-2015 08:40 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Emergency question about reflashing to stock
